I would definitely consider doing something like this *as a project*, and as the learning opportunity that it is. This is where you would explore DC-only componentry, and a small-scale project helps you determine what works best, and what works for you (sometimes two different things).
If I understand correctly, you are on-grid ... in this scenario, a "parallel (aka off-grid) system" could be a solution for you. An off-grid system, sized to critical loads you care about, is implemented parallel to grid wiring/components. For example, run the fridge 100% of the time on this parallel system (inverter/battery-bank). Recharge from the grid, using charger appropriate to battery-bank and chemistry (this is a cut-out to the grid); use best off-peak cost/time to recharge. Done, plus you have an emergency backup system in place for those (few, many in your area) times that the grid goes down. No messy "inter-tie" AHJ/codes/components/electricians/etc. to tie solar gear into the grid, as everyone and their dog wants to get a piece of you.
Later on and if needed, add a small inverter-gen to the mix, for longer runtimes when grid is down, or for larger loads. Or, add solar panels, for recharge during the day, and not from expensive grid power at that same time.
Hope this helps ...
