A bang-bang square wave inverter with no 0V dwell time might (or might not) cause some issues for a synchronous rectifier but a passive diode rectifier would also likely see some increased loss due to hard switching caused fast reversal of voltage but unlikely to cause malfunction.
I'd worried about this and will probably put in some very small zero time because I'll be scared to have both paths on at the same time with differing on- and off-transition times. Doubt it'd make it much better for the rectifier though. But then again unless there's some other capacitance in the panels (probably insufficient given the speed of MPPT scanning algos) I'll lose efficiency whenever I'm not passing that current through. And now I want to add some capacitor or inductor haha... but no, I really don't want to end up designing most of a regular inverter here! Let's see how I go with the dumb approach first.
Another suggestion, maybe see if there are any scrap/salvage OBCs for your EV you can get before you go trying to tear into your own working car.
Hahah yes, and if I can get a spare battery with it that'd be even better! You read my mind and I was looking on Pickles last night. No-one has crashed their shiny new MG EV recently though.
Yeah, you could get better solar battery to EV battery efficiency if you get a DC-DC system working and bypass the OBC I guess. Not sure the cost and effort would be justified without seeing your actual numbers however. I'd expect an OBC to have >90% efficiency and a well implemented DC-DC to have ~95% [98% on the high end]. 5% improvement might not really justify the costs. ~10% in a "best case" might also not be worth it if the costs involved are too high.
You're definitely right, though in my EV driving experience, 10% extra would be really nice sometimes! If you are limited in solar array space then it's even more important. And if you also build in the MPPT controller to avoid extra conversion stages and battery losses then you're even further ahead.
I wasn't sure if I could link YT videos from other channels here but I see you did (and thank you for those teardowns!). Here's the MPPT + DC-DC converter board that is on its way to me now, not powerful enough for my application, but let's see how it performs:
Edit1: timecode in link didn't work: go to 21:15 to see the board
Edit2: OMG I just realised the source of one of those videos. I have so much to learn. Thanks again everyone!
