Author Topic: Vertical BiFacial Solar Panel Test Results  (Read 9851 times)
Offline EEVblogTopic starter
« on: February 25, 2024, 09:39:26 pm »
Test results vs standard panels, no major surprises.
Offline Someone
    • send complaints here
Re: Vertical BiFacial Solar Panel Test Results
« Reply #1 on: February 25, 2024, 10:25:52 pm »
It really needs the full annual collection to show the benefits:
https://www.eevblog.com/forum/renewable-energy/tilting-(at)-solar-panels/
Some (cold region) users have more energy demand in winter and can bias their system toward that.
The daily production increases on the shoulders is also of benefit to people who will self consume that, and coinciding with peak pricing. Even vertical with the panels on a fixed north south alignment wouldn't be insane for people who can match their load to that.
« Reply #2 on: February 25, 2024, 11:07:15 pm »
Basically, it'll have benefits for some people in some circumstances, and only downside for others in other circumstances.
The results are basically what you'd predict with a dual sided solar panel, nothing magical is happening.
Offline Someone
« Reply #3 on: February 26, 2024, 03:27:12 am »
But you can say exactly the same thing as the rule of thumb: point north with a 30 something degree elevation. Works for some circumstances and has downsides in others. It all comes down to the specific energy demands of the user and their relative tariffs.
« Reply #4 on: February 26, 2024, 04:07:57 am »
Sure, but in the majority of cases you don't have a choice, you just whack solar panels on your existing roof and "you get what you get, and you don't get upset".
Offline Someone
« Reply #5 on: February 26, 2024, 05:52:44 am »
I see many installs around here putting in tilting frames to trim the production. Equally few houses are completely covered on all facings so there is some (possibly misguided) thought going into it.
« Reply #6 on: February 27, 2024, 02:07:39 am »
Would depend on latitude as to whether you'd bother. Can't say I've ever noticed a single home installation in Sydney that is tilted different to what the roof is. The only exception is older cheap flat roof houses.
Offline max_torque
    • bitdynamics
« Reply #7 on: March 04, 2024, 07:49:54 pm »
As the price of solar panels falls, what i see is that any kind of complex mounting structure or arrangement actually costs more than just filling the available horizontal space with panels.  Panels that are tilted to capture more insolation clearly shade a greater horizontal area, so if the cost of all that angled mounting is added up, it needs to be balanced against the cost of a simpler mounting just using more panels!
For my home array, the additonal cost of mounting panels on my "ideal" roof (40Deg, south facing, totally unshaded) that came about because of the requirement to work at height and to install suitable supporting rails through the more complex roof structure added an extra 3 years to the payback time when compared to me simply being putting more panels directly on very simple rails on a low flat roof. The saving in installation costs outweighed the loss in energy capture by a large margin (in the UK,labour costs are large, and "greentax" now seems to apply to any solar project, so it really costs to get panels put on roofs where the solar installer is not getting a large cut of the resulting grant or feed-in tarrif etc).
