Electronics => Power/Renewable Energy/EV's => Topic started by: BillMC on January 22, 2024, 09:26:29 pm
I have a certain device (portable CD/mp3 play) which like many other devices can be powered from either battery or mains power supply. When I first used it I used batteries. I then found a mains power supply and used that, because the batteries power ran out. The device continued to work without any problems. I later used a new set of batteries, but for some strange reason the device would not work, yet when I plug the power supply back in it still continued to work.
Can anyone explain the reason why it no longer works with the batteries? BTW I tried a few different sets of batteries and I even tested them wil a meter and they all have a full charge.
The power supply contact in the CD player most likely has
a switch that disconnects the battery when the power supply
is plugged in. It could be bad.
So I take it then that this switch must have permently switched off the contact for the battery input?
trace the battery circuit to the circuit board piece by piece and see if there is a circuit when you are probing a battery because consumer device battery cavities are often utter trash and the problem is compounded by small amounts of corrosion damage from burping cells etc. A dodgy switch is also a common problem.
its methodical probing that will find this problem most likely.
