Author Topic: Battery voltage drop.  (Read 1264 times)
Offline McBryce
« on: October 31, 2017, 02:40:06 pm »
Hi all,
    I was just messing about with some old batteries, setting up my DC Load for a battery capacity test. I have two old 9V batteries, both read about 7.5V with no load. If I connect either one to my DC Load and try to pull 500mA, the voltage drops to about 3V, but supplies the 500mA. All as expected so far. However, if I connect the two batteries in series (total no load voltage now around 14.8V) and try to pull 500mA the voltage drops to 0.027V and can only manage around 280mA. I wasn't expecting this, but I'm no battery expert.
I would have expected somewhere around 6V and the 500mA still being supplied, but obviously I was wrong. Is this due to the two ESRs being added together? The maths don't add up for me. Can anyone explain exactly what's happening here?
Thanks,
McBryce.
Offline IanMacdonald
    • IWR Consultancy
Re: Battery voltage drop.
« Reply #1 on: October 31, 2017, 02:59:32 pm »
The internal resistance per battery is (7.5-3)/0.5 or 9 ohms.
With two in series the volts drop across the two internal resistances (18 ohms total) with 500mA flowing would be 9v, so the terminal voltage should be (7.5x2)-9 or 6v.
I suspect you have some kind of measurement error with the result you get.
Offline McBryce
« Reply #2 on: October 31, 2017, 03:20:22 pm »
Thanks for confirming that my maths wasn't wrong.
After some experimentation I found the answer: One of the batteries seems to have an issue. It only supplies the 3V / 500mA for about 10 seconds and then drops to 0V. I suspect I didn't wait long enough when checking the batteries individually.
McBryce.
Advertise on the EEVblog Forum
