Author Topic: Bootstrap drive for two transistor forward  (Read 378 times)
Offline FaringdonTopic starter
« on: May 28, 2023, 10:26:13 am »
As you know, Two tran forward  was never a candidate for bootstrapping, since it has no "pushpull" drive for the bootstrap cap refresh.
However, the attached shows its  easily possible.
Since modern bootstrap drivers, like 2ED2109,  have immunity to -11V on the Vs pin, and CMTI of 50v/ns, then why do people still use gate drive transformers for the high side drive?
2ED2109
https://www.infineon.com/dgdl/Infineon-2ED2109-4-S06F-J-DataSheet-v02_32-EN.pdf?fileId=5546d4626cb27db2016cb8d7493e29eb
« Last Edit: May 28, 2023, 10:30:01 am by Faringdon »
'Perfection' is the enemy of 'perfectly satisfactory'
