The topic is about a non-isolated switched mode converter with negative output.
To be more specific, +400VDC supply that outputs -5VDC, about 1W.
Whenever I needed a small negative output in projects, buck was the obvious choice.
What surprised me is this application note from ST [1] and the quote (p.15):
The buck-boost converter is the simplest converter to implement a negative power supply.
It should be noted that only positive power supply can be implemented with a buck converter.What is the problem with buck? It always worked fine, see [2].
I admit I never did that with +400VDC to -5VDC so this find just puzzles.
I am aware buck-boost has the extra advantage that output can go way higher than input voltage in magnitude but I do not need that, ST AN does not need that. The disadvantage of buck w.r.t. buck-boost is that the switch needs to work accross 405V instead of 400V for buck-boost but that is just no problem.
References:
1. "Non-insulated SCR / Triac control circuits"
AN3168 ST (Doc ID 17193 Rev 1)
2. "Creating a Negative Output Voltage Using a Buck Converter"
AN76946 Vishay (25-Feb-16)
