Author Topic: Charge pump for inverting a negative power supply  (Read 2105 times)
Offline SarielTopic starter
  • Country: il
« on: October 28, 2024, 04:24:14 pm »
Hello,
Can I use a standard off-the-shelf inverting charge pump (from TI or AD) to convert a negative power supply input into a positive voltage?
Are there any specific precautions I should consider? Can I connect the charge pump in the same way as in its typical application?
Thanks!
Online PCB.Wiz
Re: Charge pump for inverting a negative power supply
« Reply #1 on: October 30, 2024, 04:02:02 am »
You did not mention what voltage and current ?
You need a charge pump that can start-up, which means the switching section needs to work initially on the supplies you have available.
Inverting charge pumps (like 7660) used for voltage doubling examples usually have 2 diodes externally.
eg A Charge pump designed for doubling, like LM7665 can double 0,5V to 10V, or can be connected 0V, -5V to 'double' that to +5V
The following users thanked this post: ahbushnell
Offline nctnico
« Reply #2 on: October 30, 2024, 02:11:46 pm »
Hello,
The only thing to be aware of is that charge pumps tend to be noisy. Some have linear post-regulators to clean up the output voltage but even then the charge pump itself can be a source of noise.
