Author Topic: Cheapo Grid Tie Inverter Efficiency Mod  (Read 1580 times)
Offline PerpetualWalnutTopic starter
« on: April 26, 2021, 09:35:35 pm »
Okay, THIRD time trying to make a new post! Page just reloads with a blank body of text and with no error messages as to why. Do posts need to be approved? If so, then why not indication of that when I click post? Anyways... I'll try again with no pictures attached this time.
I bought one of these (1000W Grid Tie inverter Solar with limiter MPPT pure sine wave DC22-60V/45-90V) off ebay a while back. I found that it would run really hot and I was only getting about 80% - 85% efficiency out of it. It's advertised as upwards of 95% efficiency! Yah right! So I tore it down to see what cheap parts they put in it. I looked at the FETs, TRIACS, and Diodes and found them all to be decent except the diodes which were standard diodes rather than high speed Schottky???
The diodes they used: RHRP8120 https://www.digikey.com/en/products/detail/on-semiconductor/RHRP8120/965460
The diodes I replaced them with: SCS210KGC https://www.digikey.com/en/products/detail/rohm-semiconductor/SCS210KGC/3902856
The inverter runs MUCH cooler now and it looks like I'm getting an extra 75 watts of power! I have yet to do an accurate recalculation of efficiency, but based of my estimates and napkin math I'm getting closer to the advertised 90% - 95% efficiency.
Re: Cheapo Grid Tie Inverter Efficiency Mod
« Reply #1 on: April 26, 2021, 09:36:38 pm »
Pictures...
« Reply #2 on: April 26, 2021, 09:37:11 pm »
Third times a charm!
« Reply #3 on: April 26, 2021, 09:38:31 pm »
Back of board.
Offline f4eru
    • Chargehanger
« Reply #4 on: April 27, 2021, 11:12:14 am »
People from manufacturing or ignorant devs probably swapped some incorrect parts !
Online nctnico
« Reply #5 on: April 27, 2021, 03:26:31 pm »
Now check EMC compliance... it might be that the design didn't pass with Schottkey diodes...
Offline Monkeh
« Reply #6 on: April 27, 2021, 03:30:24 pm »
It's bold to assume that passed any compliance tests at all.
Offline Wolfram
  • Country: no
« Reply #7 on: April 27, 2021, 03:43:22 pm »
That's quite a dramatic improvement. SiC schottky diodes are close to magic, but at a cost, which is likely why they weren't used originally. EMI is possibly lower as well, due to the lack of significant diode reverse recovery current spikes. These are commonly both a source of significant harmonic energy and switching device losses.
« Reply #8 on: May 06, 2021, 03:16:33 am »
It passed QC didn't it? That's what the QC sticker is for right? RIGHT!?  :-DD
I didn't think about EMC with those diodes, I just figured that they saw that they could get away with cheap diodes in order to cut the cost by $50 - $80
Offline Circlotron
« Reply #9 on: May 06, 2021, 05:34:39 am »
Maybe the original sales sample that was sent to the importers had SiC schottkys and later they changed them and kept the cost difference. Probably wouldn't be the first time.
