Head scratching this one. I'm counteracting the reactance of an inductor with capacitors and have computed the ideal capacitance and reactance delta which should lead the phase closest to zero.
For human use, frequency is converted to kph.
From the graph we can see the switch point is around the 17kph mark, that is, both sets of capacitors should perform about the same.
In real-life it's way off, the switch point is 27kph.
Coincidentally if I divide the inductance by half it's almost bang on at 26kph. Urm...
Anything wrong with the calcs?
