Author Topic: "Tricking" a Capacitor?  (Read 2201 times)
Offline johnywhyTopic starter
« on: October 09, 2024, 04:02:33 am »
With an OOK-modulated, high frequency, high current carrier, if you filter out the high-frequency carrier, will the modulator frequency remain, providing the same current as the original carrier (with losses)?
« Last Edit: October 09, 2024, 04:04:36 am by johnywhy »
Offline Andy Chee
Re: "Tricking" a Capacitor?
« Reply #1 on: October 09, 2024, 04:12:34 am »
Definitely not the same current.  A certain amount of current will be dissipated as heat within the filter.
AM crystal receiver is essentially what you seem to be replicating:
https://en.wikipedia.org/wiki/Envelope_detector
....except you seem to want a "power" version.
« Reply #2 on: October 10, 2024, 06:07:28 am »
You mean losses? So, Isupply - filterLosses = Ioutput.
Offline Andy Chee
« Reply #3 on: October 10, 2024, 06:45:10 am »
Correct.  Filter losses are unavoidable.
Offline f4eru
    • Chargehanger
« Reply #4 on: October 10, 2024, 11:44:21 am »
if you use a linear low pass filter, the output will be zero (except on abrupt changes).
You probably first need a non-linear element, like a diode bridge (also with losses)
« Reply #5 on: October 11, 2024, 05:59:42 pm »
The "abrupt changes" is the modulation happening below the cutoff freq of the filter.
You mean a rectifier? Won't that convert AC to DC? I don't want DC output, i want AC output.
Offline Andy Chee
« Reply #6 on: October 11, 2024, 11:29:46 pm »
Not necessarily.  As you can see in this diagram, a diode by itself will create a pulsed output which is definitely not DC:
https://en.wikipedia.org/wiki/Pulsed_DC#/media/File:Rectification.svg
