Hi.
TL;DR: I only want to understand the principle. There may be a better way to design this, I'm only interested in *understanding* if/how a triac can work together with a relay the way I described it.I'm designing a power stage for two heaters on my modded oven. Because of available space I can't install a solid state relay. I've also come to prefer zero crossing instead of using relays only. So my choice went to a MOC3043, doubled with a triac, as the datasheet recommends (see
https://www.onsemi.com/pdf/datasheet/moc3043m-d.pdf).
The switched currents (AC) will be between 5 and 10A (measured). Since I fear (and am almost certain) the triac I've chosen (MAC9NG, see
https://4donline.ihs.com/images/VipMasterIC/IC/LFSI/LFSI-S-A0012699119/LFSI-S-A0012723662-1.pdf) will blow up, even if mounted on a heatsink (which can only be small due to lack of space), I've thought of adding a relay (G5CA is the one I have, see
https://components.omron.com/us-en/asset/53866) in parallel with the power triac (see the red outline in the picture below) to turn ON after being certain the triac conducts¹.
Regardless of whether it's a good idea (I suppose it's not), I'd like to know (
because I want to understand) what happens when the relay contacts turn OFF: will the power triac remain ON or will there (potentially) be a spike when the contacts are OFF, say in the middle of a peak? I can find valid argumentation in both cases (i.e. "there will be a spike" and "there won't be any") which translates my misunderstanding of the MOC + triac pair.
So the question is:
assuming the MOC is turned ON, what happens when the relay is switched OFF? Will the current be maintained by the triac or will it be cut off, defeating the purpose of switching ON/OFF at zero crossing only?
Thanks a lot in advance.
¹ In that shape, the relay is always switching off first and then the MOC is turned off after a given delay, which is greater than the rated time for the contacts to be released.
