Author Topic: doubt chemistry CR2032 battery  (Read 1708 times)
Offline ranger87Topic starter
« on: November 21, 2022, 11:58:42 am »
What is the chemical composition of the CR2032 battery?
Is it an oxidative corrosive chemical composition for metals and PCBs?
over the years and storage battery this chemical composition of CR2032 changes and turns into a corrosive oxidative chemical compound that leaks and corrodes?
Offline hexreader
Re: doubt chemistry CR2032 battery
« Reply #1 on: November 21, 2022, 12:31:34 pm »
Wow!
Two new aliases and two new countries just today - it is hard to keep up....
Here is what I know so far:
31 User names:
gamemaniaco, John rodrigues, johnroduigues, Gamer87, gamer87, gamer1987, micksmelanie, james23051987, Alucardps1, cloudff7, cloud ff7, johnmullins, scatmanjohn, classicsamus87, classicsamus, classicjohn, hardwarepc86, robertart, electroenergy, eletroenergy, junior1987, tsubasaoliver, electroenergy88, Mario Snes, tiago1986, cloudff7ps1, Alucardps1, iStef 1, barretff7, samusaran87, ranger87
26 Forums:
allaboutcircuits - james23051987, micksmelanie (banned), classicsamus87 (banned), hardwarepc86, junior1987 (banned), electroenergy, barretff7
Edaboard - Gamer87 (banned), John rodrigues (banned)
ETO - cloudff7 (banned), classicjohn (banned), eletroenergy, samusaran87
Maker Pro (was Electronics Point) - gamer87, johnmullins, scatmanjohn, classicsamus(banned), tsubasaoliver (banned), electroenergy88 (banned, but re-instated)
EEVblog - micksmelanie (banned), johnrodrigues (banned), classicsamus87, robertart, tiago1986, carlosff2, ranger87
Electronica Pt - gamer87, Alucardps1, cloudff7
badcaps.net forum - gamer87 (banned)
EverDrive - cloudff7
WD community - gamer87
tom's hardware - cloudff7, cloudff7ps1
scienceforums.net gamer87
eepower - cloud ff7
StackExchange - Mario Snes
Dingoonity - gamer87
DigitalFAQ forum - gamemaniaco(banned)
VideoHelp forum - gamemaniaco(banned)
ImgBurn forum - gamemaniaco
CDRinfo forum - gamemaniaco
eletronica2002 forum - gamemaniaco
physicsforums - gamer87
scienceforums - gamer87
ST community - iStef 1
microchip forum - gamer87
afterdawn forum - gamer1987
From Brazil, IP address Brazil, but claiming UK, New York, Andorra, Argentina, Autralia, Bolivia, Belgium (Bruges), Denmark, United States
Behaviours:
Storing things, flooding multiple forums, opening multiple accounts, asking the same question over and over, lying
Devices:
SNES, PS2 Slim 90000
The following users thanked this post: thm_w, edavid, voltsandjolts, pardo-bsso, MK14, jpanhalt, Geoff-AU, I wanted a rude username
Offline jpanhalt
« Reply #2 on: November 21, 2022, 12:35:53 pm »
Have you read this thesis: https://www.gutenberg.org/files/14986/14986-h/14986-h.htm
All batteries produce electrical current by oxidation/reduction reactions, aka "REDOX" reactions.  The CR2032 is no exception (https://en.wikipedia.org/wiki/Lithium_metal_battery ).
Quote from: Michael Faraday
The anode is therefore that surface at which the electric current, according to our present expression, enters: it is the negative extremity of the decomposing body; is where oxygen, chlorine, acids, &c., are evolved; and is against or opposite the positive electrode. The cathode is that surface at which the current leaves the decomposing body, and is its positive extremity; the combustible bodies, metals, alkalies, and bases, are evolved there, and it is in contact with the negative electrode.
Whether a battery leaks is mostly a matter of how it is constructed, albeit some chemistries seem to be more prone to leakage and causing damage than others.
Offline voltsandjolts
« Reply #3 on: November 21, 2022, 01:26:15 pm »
@hexreader
Nice work :-+
I have no idea how you gather that info, some automated method...or must be quite some time?
The following users thanked this post: hexreader
« Reply #4 on: November 21, 2022, 01:32:04 pm »
My guess he is a member of all those boards, or just used a search to find those common questions, using an exact text match mask.
Offline hexreader
« Reply #5 on: November 21, 2022, 01:32:27 pm »
@hexreader
Nice work :-+
List built up over the years since 2017, plus a little Googling
What I hate most are the blatant lies that insult the intelligence of all of us
I worry that this obsessive behaviour of mine is more obsessive than gamer87
... or maybe it is an over-blown sense of justice or fairness?
I guess gamer87 and I both need therapy  :'(
EDIT - just found a CR2032 question from 1 May 2016
Six and a half years ago
https://www.electronica-pt.com/forum-eletronica/eletronica-geral/90720-duvidas-sobre-bateria-cr2032?limitstart=0
« Last Edit: November 22, 2022, 10:02:56 pm by hexreader »
The following users thanked this post: SeanB, thm_w, voltsandjolts
« Reply #6 on: November 21, 2022, 03:30:14 pm »
Some people say that cr2032 leaks others say that cr2032 does not leak and I am in doubt if I can keep them on the PCB or remove them all because of leakage and corrosion of the pcb
Offline xmris
« Reply #7 on: November 21, 2022, 06:28:15 pm »
@hexreader
if you have/keep more details pls update the https://www.stopforumspam.com/
it's a valuable tool, I m admin on a forum and this database is quite handy.
READY.
Offline 2N2222A
« Reply #8 on: November 25, 2022, 11:55:49 pm »
Behaviours:
Storing things,
Storing things?
Offline xmris
« Reply #9 on: November 26, 2022, 09:21:37 am »
READY.
Offline bidrohini
  • Country: bd
« Reply #10 on: December 17, 2022, 07:34:06 am »
Specifically, the CR2032 battery is a Lithium-manganese dioxide battery (LiMn02). It is composed of a Mn02 cathode and a lithium anode. The construction of a typical CR2032 battery features a stainless steel case to prevent any leakage of the non-corrosive electrolyte.
