The UK had (for a while) an insane feed in tariff for renewables (Which they paid even if YOU used the power, got to love a tory government giving a freebie to the home owning classes).
A mate of mine spotted the obvious opportunity here and had a solar system installed, then went out and bought a fat old server power supply, some judicious wiring and control gear later and he had 4kW of 'renewable' feed in running 24 hours a day!
During the day, 4kW from the solar, then at night 4kW from taking his 'renewable energy' back out of the grid (Remember he gets paid feed in rate for supplying it but it is net metering for usage!), stuffs it thru the power supply and back into the inverter and feeds it in all over again. Doing the efficiency sums, some of that power ran around the power supply->inverter->meter->power supply loop about 10 times.
It lasted for years before someone got wise.
