Mwah the gateway was optional so the owner can see the statistics.
... which makes the thing unappealing bait-and-switch. "Here, buy this more expensive, more complex, less reliable premium system, but hey, it gives you fancy extra features like per-panel monitoring, which also helps with the unreliability!" ... "you can buy it without the monitoring!" This is like buying a Ferrari with 1.4-liter motor as a cheaper option, no one wants it, it makes no sense.
This same pattern is all over microinverters. "Buy this premium thing which produces more from the same light!" ... "By the way, it has worse efficiency, it has insufficient current rating so MPPT flats out in optimum conditions and you lose production, oh and it thermally throttles and you lose production."
All that is left is mental
image of premium, with all premium really stripped off, because their manufacturers failed to keep improving their products. Even failed to keep them up-to-date. And I don't blame the designers, it's a very difficult engineering task.
During the same time, string inverters gained two or three MPPT trackers, remote monitoring, and nearly free-of-cost battery port. Just what people wanted and needed. And they do it for cheap.
Really, the competition is already over.
I can still see there is potential in distributed inverter topology but it needs some significant change in mindset how these things are designed; better integration and even more serious cost-cutting without undermining quality. A harsh equation.
