Cycle life is regarding full cycles between 100% and 0%, using the standard charging and discharging conditions like current, stopping condition etc. specified in the datasheet.
Partial cycles have the tendency of wearing out the cell much less than expected from the amount of charge transferred. For example, if a cell is rated for 500 cycles 100%-0%, using it only between 70%-20% (i.e.: depth of discharge is 50% instead of 100%) increases number of such cycles way beyond the expected 1000 cycles, can be 5000-10000 cycles for example.
There are other factors too, for maximum cycle life avoid charging at low temperatures (optimum would be somewhere around 30degC), and limit charging current near full. For example, if you have to fast charge at 0.8C, instead of running at 0.8C all the time, charge at 0.9C until 4.0V then at 0.6C. Small optimizations like that can have big difference.
But all the exact details depend on the actual cell pretty much. Even given the same cathode chemistry, different manufacturers have their own different secret sauces which behave differently.
