Author Topic: Step-down transformer tripping circuit breaker  (Read 3612 times)
Offline MindBenderTopic starter
« on: September 05, 2023, 07:26:19 pm »
I recently bought a 240V/120V step-down transformer to power my 120V JBC soldering tools from our 240V mains. It’s ha hefty 2000VA version, because both tools are 700Watt each, and 1500VA seemed a bit tight.
Now when I switch it on, even if it has no load connected to it, the circuit breaker for that circuit trips. It is an ABB, 16A B-profile with internal 30mA GFCI.
At first I thought it was tripping because of a ground fault, but disconnecting PE didn’t make a difference. However, connecting it to my isolating transformer did make a difference; The circuit breaker didn’t trip, but at switch-on the isolating transformer made a clean 50Hz hum that faded out in a few seconds, so it may be high inrush current, and a rather long one at that.
When I used my variac for the same purpose before I bought this step-down transformer, the circuit breaker also tripped every now and then. Both step-down transformer and variac are mono-transformers, transformers with just a single coil.
Does anybody know what’s going on here? And how I can fix this, if it is fixable?
Thanks in advance.
Offline MF-jockey
Re: Step-down transformer tripping circuit breaker
« Reply #1 on: September 05, 2023, 10:46:02 pm »
The high inrush current is caused by the magnetization of the transformer.
https://youtu.be/kn9QOF5d-Sw
When I switch on a larger transformer, I use a series resistor (wire resistor 15 to 68 ohms, at least 10 W type) and a time relay which bridges the resistor after about a second.
The resistor should be mounted in such a way that it cannot cause a fire if the relay fails.
There is also a circuit variant with NTC and relay.
Then there is the luxury variant, the electronic transformer switching relay "TSRL" from FSM AG.
https://www.fsm.ag/de/trafosanfteinschalter/produkte/tsrl, sorry only in german.
« Last Edit: September 05, 2023, 10:52:05 pm by MF-jockey »
The following users thanked this post: MindBender
« Reply #2 on: September 06, 2023, 07:13:52 am »
Thanks for your reply!
The good news I take from this is that it is a very normal and well-understood phenomenon. Not well-understood by me though; The inrush seems to last longer than 1/4 for the wave period. I've watched the video, and I'm sure people with a better understanding of the integral formulae shown will understand why. But I'm not pursuing that understanding right now.
Interesting! This TSRL comes in many variants, of which the simplest is exactly what you described; An NTC with a timer relay to bridge it:
http://www.trafo24.com/epages/79921744.sf/de_DE/?ObjectPath=/Shops/79921744/Products/TSR-0016
Unless you have all parts laying around (which I probably have) and you still know where to find them (which I probably do not), the price is pretty hard to beat for something pre-made, tested and working.
There's also a version that prevents the inrush current all together, instead of limiting it:
http://www.trafo24.com/epages/79921744.sf/de_DE/?ObjectPath=/Shops/79921744/Products/TSR-0009
I wonder if this is better for my application. It doesn't limit anything in case of over-current, the datasheet says, but NTCs have a limited life span. Decision paralysis...
Offline Psi
« Reply #3 on: September 06, 2023, 07:21:50 am »
Could put a incandescent lamp in series with in the primary then a relay across the lamp with the relay powered off the output of the transformer. Not the best solution, but its easy to build with parts lying around.
« Last Edit: September 08, 2023, 11:18:11 am by Psi »
The following users thanked this post: MindBender, DenCraw
Offline woodchips
« Reply #4 on: September 06, 2023, 08:35:33 am »
Why not just change the MCB from the B rating to a D rating? D is for transformers, C for motors, B for lighting, A for resistive, just the amount of inrush current the load has.
« Reply #5 on: September 07, 2023, 06:37:48 pm »
Could put a incensement lamp in series with it the primary then a relay across the lamp with the relay powered off the output of the transformer. Not the best solution, but its easy to build with parts lying around.
I recall when I was still in school, the loudspeakers for experiments in the physics room had an internal series light bulb for exactly that purpose. It's a nifty trick.
Well, those are expensive, but also; This MCB doesn't just power my office, but also other rooms in the house and that just doesn't seem right. And I wouldn't be able to use my iron in the other half of the house.
Anyway; I ended up ordering the TSRL from FSM AG. They seem to be very widely used.
Offline themadhippy
« Reply #6 on: September 07, 2023, 07:18:55 pm »
Bit of a generalisation going on there.type A's are hardly ever seen in the wild,even on purely resistive loads,and if type B is for lighting what about low voltage lighting circuits that are transformer fed? And what about the earth loop impedance of the circuit,a type D  requires a much lower value  compared to a type B
Offline MF-jockey
« Reply #7 on: September 15, 2023, 12:18:05 am »
By the way, this is also a TSRL from FSM, they have patents on it.
« Reply #8 on: September 17, 2023, 02:17:36 pm »
Ah; I was wondering about that during purchase, because I didn't want to buy an imitation. But it got here a couple of weeks ago, and it did indeed carry FSM and TSRL marks.
It is installed in the transformer housing and it works brilliantly! Thanks again for the tip.
