Author Topic: Full Bridge LLC of 4kW not possible with offtheshelf gapped cores  (Read 1199 times)
Offline FaringdonTopic starter
Hi
Do you agree that a 4kW Full Bridge LLC converter, with vout = +/-180Vdc and Vin = 390Vdc (PFC output) cannot be done with any offtheshelf gapped ferrite core sizes? (That is, cores that can be bought ready_gapped)
AYK, the biggest gapped ferrite core available offtheshelf is the ETD59 which is offtheshelf gapped to 2mm (AL = 311). However, if that is used as resonant inductor or (external) magnetising inductor of such an LLC, then its core losses will be too high (approx. 10W).
Would you agree with this? Or can you design one which doesn’t suffer such high core losses when only offtheshelf gapped cores are used.
The attached shows the design document for such an LLC. Done at 70kHz….the core losses come out at 10W for the resonant inductor, and 10W for the magnetising inductor, which in both cases uses the ETD59 TDK core with N87 , ready gapped with 2mm gap. These core losses are too much, would you agree?
'Perfection' is the enemy of 'perfectly satisfactory'
Offline jonpaul
Re: Full Bridge LLC of 4kW not possible with offtheshelf gapped cores
« Reply #1 on: May 22, 2022, 11:10:52 am »
No, Farrington.
To summarize your misconceptions
 a 4 kW inverters loss budget easily accommodats 20 W Pfe.  Pcu may be similar.
Gap calcution depends on the overall topology, frequency, inductance and Bmax
Stock gapped cores are in several gap sizes,
expect 1..3 yrs delivery and MQ 10K sets
We use un gap cores and place a fish papers or G10 gap.
Our inverters had no gap in the transformers.
bon courage
Jon
Jean-Paul  the Internet Dinosaur
The following users thanked this post: Faringdon
« Reply #2 on: May 28, 2022, 11:30:35 am »
Thanks jonpaul,
I like the idea of sheet gapping, but fear  of its inaccuracy, and wide tolerance.
Also, thats now two of us that spell my name wrong!....its supposed to be "Farringdon", after my favourite area of London.
..will see if i can get it changed.
Also, i still declare that a 4kW LLC converter cannot be done  off PFC output (~390V)  with offtheshelf gapped ferrite cores.....so the ETD59 is the biggest offtheshelf gapped ferrite core with 2mm gap to AL=201.
It is simply not possible...would be too much core loss even with fan cooling on  the ferrite and vented enclosure in max 35degc  external ambient.
Would you agree?
« Last Edit: May 28, 2022, 11:34:38 am by Faringdon »
Offline Wolfram
  • Country: no
« Reply #3 on: May 29, 2022, 09:15:56 pm »
No, I disagree, and I have personally made an LLC converter processing more than 10 kW with an off-the-shelf gapped PQ65 core set.
« Reply #4 on: May 29, 2022, 09:42:45 pm »
Thanks, but PQ65_with_gap  is not "offtheshelf"......at least not with major vendors........and not universally gapped amongst the different vendors.
Whereas ETD59 is standard gapped to up to 2mm.
You must have had that gapped?...or sheet gapped it?
TDK PQ65
https://product.tdk.com/system/files/dam/doc/product/ferrite/ferrite/ferrite-core/data_sheet/80/db/fer/pq_65_60.pdf
[EDIT.]...My apologies...it is actually available"distributed gapped" off the shelf..(if you can find it in stock like that)......but £46.44 a piece on digikey...12 in stock
https://product.tdk.com/system/files/dam/doc/product/ferrite/ferrite/ferrite-core/data_sheet/80/db/fer/pq_65_60_dg.pdf
....that to me is just as pricey as getting it gapped yourself....so it woudlnt count for us....though my apologies , because i forgot to add that  "if available off the shelf, then mustnt be of a price equivalent to getting it gapped yourself"
Price falls with volume of course..but so do the others.
............................_____-----____
For comparison, if you will, please see offthe shelf gapped ETD59......£3  a piece......
https://www.digikey.co.uk/en/products/detail/ferroxcube/ETD59-31-22-3C94-G200/7651633
As such, ETD59 is  the biggest of the  'realistically offtheshelf gapped ferrite' available....but it woudlnt be possible to do a 4kW LLC off 390Vdc with a ETD59....thats the postulation....unless others may differ?
« Last Edit: May 29, 2022, 09:58:43 pm by Faringdon »
Offline uer166
« Reply #5 on: May 30, 2022, 12:48:18 am »
I postulate that you can do a 10MW power supply using nothing but ETD59 cores. You didn't qualify how many cores do you allow being used, and as such this entire thread is a waste of server space.
« Reply #6 on: May 30, 2022, 01:56:48 am »
Thanks, i meant  no more than one ETD59 for each of .....
*...LLC transformer (doesnt need gap)
*...External magnetising inductor (needs gap)
*....External resonant inductor   (needs gap)
Offline Wolfram
  • Country: no
« Reply #7 on: May 30, 2022, 09:59:17 am »
Are you actually trying to make a 4 kW LLC? Or are you just trying to prove that it's impossible under some very convoluted and ever-changing set of circumstances?
There are off-the-shelf gapped PQ65 cores for less than 10 euros a set in moderate quantities, available from stock in Europe.
Offline jonpaul
« Reply #8 on: May 30, 2022, 12:33:26 pm »
Rebonjour Cher monsieur
Sheet gaps  are commonly used and materials available at any thickness and accuracy
Core Al is normally 20...50% tolérance +/-
Finally spcialty custom fabrication of core gaps in stock ungappd cores is offered by many core importers and distribution.
In USA I can mention Fair-Rite,  AllMag, Elna  Ferrite, etc
As a surface grinder with diamond tools and slurry is used, expect a set-up fee and high per item costs
For these reasons for decades we used easily changeable sheeet gaps of G-10 fiberglass available in 32, 64, 128 100 250 mil thickness from electrical insulation suppliers like EIS and Essex Brownell
Bon courage
Jon
« Reply #9 on: May 30, 2022, 03:06:51 pm »
Thanks, thats interesting with the sheet fibreglass......like FR-4 PCB material.....i wonder on the tolerance of thickness, since AYK,  external resonant  inductor and external magnetising inductor of LLC needs to be fairly tight tolerance in its inductance.....within +/-10% and prefereably +/-5%.
Yes i agree ungapped core tolerances are around 20-50% tolerance.
Also, thanks for the info  on slurry and diamond used in gapping...sounds a nightmare for cost
