Author Topic: High Voltage, Variable 300Volt DC, 300mA SMPS  (Read 3150 times)
Offline IoannisTopic starter
  • Country: gr
« on: December 01, 2024, 05:54:35 pm »
Hi.
I would like to improve my current design of a Power Supply that is mainly linear with SCR rectifier control and has these specs:
Line power 120 or 230 Vac
Output variable 40 to 220 Volt DC
Current max 400mA
There is a torroid Xformer that outputs 200Vac, this is rectified by SCR and then a P-channel MosFet controls the output voltage. A circuit compares the output voltage with the rectified voltage on the filter capacitor and controls the SCRs so that voltage drop on MosFet is not more than 7-10 volts, so that Power Loss is kept at minimum.
I'd like to make a better design and use switch mode topology, with cheaper ferrite Xformer. What would you recommend to use and have similar specs?
Thanks,
Ioannis
« Last Edit: December 01, 2024, 05:56:23 pm by Ioannis »
Offline jbb
Re: High Voltage, Variable 300Volt DC, 300mA SMPS
« Reply #1 on: December 01, 2024, 08:50:58 pm »
You know… the solution you’ve got sounds pretty good. I expect it’s got quite good ripple and noise characteristics, but is a bit heavy.
Do you really need another design?
I ask because designing a switch mode converter for a laboratory supply is quite a lot of effort. If you only need a small number, it may be best to get more of the same one you’ve already got.
If you really want to pursue a switched mode design, I suggest you have a read of https://magna-power.com/learn/white-paper/current-fed-power-processing where they make quite a good argument in favour of a current fed architecture.
The following users thanked this post: pardo-bsso
Offline jonpaul
    • IEEE Spectrum
« Reply #2 on: December 02, 2024, 11:15:01 am »
A walk down memory lane.....
My 1960s (high school/college) 0-400V 250 mA tube lab supply.
Based on the classic RCA tube manual and Heathkit linear series regulator
Your thoughts?
Have a great day !
Jon 2451345-0
An Internet Dinosaur...
