Hello,
What's a simple, low-parts-count way to do this?
I need to convert 120 V, 60 Hz AC USA mains to 5V, 5A, 100Khz varying DC voltage.
For convenience, assume we'll use an off-the-shelf isolated mains-to-DC converter for the first stage. You decide your preferred specs of the off-the-shelf mains-to-DC converter for the first stage.
Therefor, this question only concerns the design of the second stage, the DC/AC inverter.
There are two acceptable outputs. We'd like either one, because we need to test both.
It could be the full unipolar sine wave, with peaks are at 0V and 5V. (see attachment)
Or it could be a truncated sine pulse (see attachment). I didn't say "half rectified" because that makes an assumption about how the pulse is produced.
Voltage regulation should be +/- 1%.
Current limiting not needed, but need short-circuit protection.
The "0V" mustn't go negative, not even a little.
We need sine to improve efficiency of all following circuitry, and reduce various drawbacks of a non-sine PS, eg noise, and because our load wants smooth power. So wave-form-symmetry/distortion is important. I assume it can be a pretty decent but not perfect sine, and still get those benefits. So i assume a very low-res modified sine won't do, but a hi-res MSW may be fine. (see attachment)
I'll try to characterize the load. I believe the impedance of the load is: @1kHz AC, 8 mΩ
I don't know if Ringing, Flyback, and/or, Inductive/Capacitive-Reactive-Load considerations are important. We may have this coupled inductor before the load.
https://www.coilcraft.com/en-us/products/power/coupled-inductors/1-1-shielded-coupled/msd_h/msd1260h/msd1260h-472/ There won't be any sudden transients.
We want voltage regulation, not current regulation. So it's a constant voltage PS. The load will send a control signal back to the PS to regulate voltage as needed.
Frequency stability/accuracy isn't important.
PWM is fine, but not required. I wonder if we can achieve this with PWM, a sine driver, and a single mosfet, rather than H-bridge.
I'd like to accomplish this without a uC, if possible. Unfortunately, the EGS002 is restricted to 60 Hz.
I'm fine doing this with all off-the-shelf modules. That's actually preferred in the short-term.
Thx
