Split units heating and cooling is pretty much standard, it is rare to find cooling only, as the extra cost of adding in the valve and the extra wire is minimal, especially as almost all of the units will be expected to do heat pump duty at least part of the time, so having 2 separate but near identical models is silly. Only difference will be the programming of the controller, and the valve, along with the 2 direction cap tube needed to allow the switching. After all, if you want cooling only it is easy to simply select that on the remote, instead of leaving it in auto mode, where it will cool or heat as appropriate.
