I would like to preface this question with a story of my troubles:
I have noticed that in the evening when I have my dimmable LED lights on, I notice a slight change in brightness (flicker). It's not really periodic, but consistent.
Almost all of my lights in my home are LED and dimmable, and all show the same behavior. Same with LED non-dimmable bulbs.
I didn't bother with the flicker until I noticed that when I am running my washing machine (which has a very clear periodic wash cycle which can simply be described as 1sec motor on, 1sec motor off, and repeat for 15 minutes) that I can see the wash motor pattern in the flickering.
This find lead me to believe that different power draws around my house may be causing the flicker. So I set up an experiment to see if the flicker wouldn't show up if I were to unplug as much as I thought was reasonable. I unplugged my wifi router, refrigerator, smart-home devices. And still I was seeing the occasional flickers.
Just today, I set up my scope in roll mode to view the AC voltage from one of my outlets. I see random and some periodic voltage drops (on the order of 2 to 6Vrms). I'm assuming this is somehow caused by neighbors? One of the more curious ones is a drop of approximately 3.5Vrms which lasts exactly 10 seconds, and occurs periodically with 200 to 400 second delays.
Before I get a chance to observe the supply this evening to see how low voltage drops must be to show observable flickers, I was wondering if anyone else has encountered such an issue, and is there a fix to it? I don't have solar, but would a solar battery help alleviate this issue? Or is there a filter for such cases? I'm assuming if the transition between higher/lower and lower/higher voltage wasn't so sudden, the flicker would be much less noticeable.
