Electric heating based on thermal storage was becoming popular in the UK in the 1970s.
There were a number of methods:
Individual floor-standing block storage heaters, similar in size to a central heating radiator but a bit deeper, one or more fitted in each room that needed heating, heat being stored in refractory bricks which were surrounded by thermal insulation and had dampers to control air convection currents through them to heat the room.
A version similar to the above but usiing a single centrally positioned heat storage core, about the size of a wardrobe heat was distributed from it by blowing air through channels in the core that then went via ducts to grills in the rooms as required.
Using the concrete floor slab as a heat store - saved space but not as controllable as you could not easily prevent heat escaping from it if little or no heat was required.
These schemes were expanding in the era where the propaganda claimed that nuclear energy would be so cheap it would hardly be worth charging for it, they all fell out of popularity as the price of electricity rose and became uncompetitive against gas.
