Author Topic: Reversible rectifier.  (Read 2840 times)
Offline MikePTopic starter
  • Country: ua
« on: December 18, 2024, 12:34:09 pm »
 Hallo.
 Please share information and examples about reversible rectifier. That is, we are talking about the possibility of changing the polarity of the output voltage.
 Thanks.
Offline f4eru
    • Chargehanger
Re: Reversible rectifier.
« Reply #1 on: December 19, 2024, 10:36:08 pm »
for what purpose ?
Offline KD0CAC John
« Reply #2 on: December 20, 2024, 02:06:01 am »
1st same as last - what are your trying to do ?
I ask , because I do not think there is such a thing - rectifiers are made with diodes = diodes pass current in one direction " only " ?
Half way - 2 diodes
full way - 4 diodes
Offline themadhippy
« Reply #3 on: December 20, 2024, 02:11:37 am »
leave the rectifier alone and just swap the output wires around
Offline HackedFridgeMagnet
« Reply #4 on: December 20, 2024, 03:02:27 am »
something like that, except change the battery for the rectifier.
the switch contacts wont like the motors though.
Offline Whales
    • Halestrom
« Reply #5 on: December 20, 2024, 04:13:39 am »
HackedFridgeMagnet's example is goof if you want to use a manual switch.  The electronically controlled equivalent of this is called a "H-bridge".
Are you after sinusoidal output voltages (hard), or just reversing the direction of a DC voltage (easy)?
Offline Seekonk
« Reply #6 on: December 29, 2024, 07:47:25 pm »
That brings back memories of very early 60's.  Popular electronics had a project with a transformer, germanium power transistor  and low ohm pot. Essentially they used the transistor as a dual diode and the pot would eventually short out one diode or another.
