I'm building a usb powered device that, at present, is plugged into a raspberry Pi 3B that is powered by a digital bench supply (Rigol DP832A) at 5V with no current limit.
Measuring the voltage on my prototype device I see about 140vpp on vbus (noise), and periods of voltage dip. I believe these dips are when the PI is performing some power heavy operations, either cpu or wifi.
Attached image shows (traces from top to bottom):
- yellow = usb vbus
- teal = after FB
- red = near AD8313 pin, so after 10 ohm resistor and on the net with the filtering caps and AD9313 VPOS4 pin
- blue = 3.3v (also filtered with pi filter, generated from LDO on filtered 5V rail)
The prototype has a PI filter with FB on 5V, the signal looks basically the same on both sides of the filter. I've even tried adding ~10uF of capacitance on the output side and 4.7uF on the input side with little change. (I'm guessing this may not be enough capacitance).
If I power my prototype directly with the bench supply I don't see these dips.
I've got some RF circuits on the device, in particular an AD8313 rf detector. I'm not sure that these power fluctuations have any impact on the performance of the circuit. Nevertheless I was hoping to see if anyone had guidance on various approach of ensuring usb vbus was rock solid.
Lest readers think I'm just spam posting without thought, a few ideas came to mind.
- Use an LDO to regulate vbus down to 4.7V. FTDI usb-serial can operate with VCC at that value, AD8313 the same. Regulating down to 4.7V would provide a consistent voltage even when vbus drops.
- Look to add 30uF - 50uF of bulk capacitance to the filtered side of the ferrite bead. In-rush current would concern me.
- Select a better FB. The one at present is only 30 ohms @ 100MHz, I found a few others that are 120 ohms @ 100MHz. This could help reduce the higher frequency noise in the system, improving RF performance.
