Author Topic: Increase life of electrolytic capacitors?  (Read 3557 times)
Offline FaringdonTopic starter
« on: July 09, 2021, 08:41:12 am »
We are doing an offline 180-265VAC Flyback (15W) with Mornsun LS15-13B12 AC/DC power module. We must add a primary side HV DC bus capacitor….
Which of the following capacitance choices would dry out quicker?...
1…One 33uF , 450V EKXF451ELL330MM20S Electrolytic capacitor
OR
2..Two 68uF , 250V UCY2E680MHD3TN Electrolytic capacitors in series.
Please also answer with relation to…
A)…Flyback on 1W standby load all the time
B)…Flyback on Full power all the time…approx. (200mA of AC rms ripple current at 100Hz)
EKXF451ELL330MM20S Electrolytic capacitor datasheet (33uF, 450V)
https://www.chemi-con.co.jp/products/relatedfiles/capacitor/catalog/KXFLL-e.PDF
UCY2E680MHD3TN Electrolytic capacitor datasheet (68uF, 250V)
https://www.nichicon.co.jp/english/products/pdfs/e-ucy.pdf
'Perfection' is the enemy of 'perfectly satisfactory'
Offline bob91343
Re: Increase life of electrolytic capacitors?
« Reply #1 on: July 09, 2021, 05:56:09 pm »
Two capacitors will be less reliable than one, if you need the capacitance.  If one fails, you are out of luck, and since you have two, you double your liability.
None of this deals with drying out.  That is more a function of quality of seal and purity of materials.  The higher temperature rating parts are less likely to fail in this way.
The following users thanked this post: Faringdon
Online wraper
  • Country: lv
« Reply #2 on: July 09, 2021, 06:16:05 pm »
Except it's not. They are in series and either of them failing obstructs operation of second cap. Not to say connecting capacitors in series generally is not a good idea to begin with, and comes with it's own issues.
« Reply #3 on: July 09, 2021, 08:02:38 pm »
Thanks, the thing is that as    you know, the 68uF,250V caps have twice the ripple current rating as the single 33uF, 450V capacitor. As such,  would you think that they would run cooler and thus be les likely overall to dry out?...or may thus take longer to dry out.
Also, on the same note,  is a longer capacitor less likely to dry out then a shorter, squatter capacitor, because more of the dielectric is distant from the seal? And on the same note still........what about squirting some silicone rubber round the capacitor base so that the bottom seal is kind of more "blocked up" and less  able to vent dielectric?...will that mean it taking longer to dry out?
I once took apart a Philips DALI  radio receiver, which dims streetlights, and they had two 250V electrolytic capacitors in series in there. (As the offline flyback primary  DC bus capacitor.)
« Last Edit: July 09, 2021, 08:10:46 pm by Faringdon »
Online bdunham7
« Reply #4 on: July 09, 2021, 08:56:32 pm »
You misread him, I think.  He said 'liability' not 'reliability'.  The idea being that if you have two parts and need them both you now have two ways to have a critical failure.  But this is applying a more sophisticated analysis than this idea deserves...
The following users thanked this post: wraper, Faringdon
Online bdunham7
« Reply #5 on: July 09, 2021, 09:02:15 pm »
OR
Actual iife and reliability results rarely line up with simple assumptions based on a few datasheet parameters.  The first capacitor has very long specified life, you've derated the voltage a decent amount and the ripple current is only about 25% of its rating at full power, thus it seems a good fit.  Nobody can predict exactly how long it will take to 'dry up', but at a reasonable operating temperature, probably a very long time.  High quality caps often outlast the other components.  Filter caps in series is not a commonly used method and I'm pretty sure that solution will be less reliable.  You would need to balance them as well.
« Reply #6 on: July 09, 2021, 11:17:53 pm »
Thanks, balancing is interesting here....peak of high mains is 373V.....so if we imaging one capacitor has 250V on it, then the other would have 123V on it....but this level  of imbalance is extremely unlikely.......and even that imbalance is OK since the caps are 250V rated.
Offline bob91343
« Reply #7 on: July 10, 2021, 01:14:07 am »
Blocking the seal with rubber or anything else may not be wise, as it may be used as a vent.  A vent is important in case the internal pressure increases.  Better to make a mess and lose capacitance than have an explosion.
Offline Siwastaja
« Reply #8 on: July 10, 2021, 06:58:00 am »
Just say no to series capacitors because you don't have to go there, plenty of 450V rated parts are available. If you have shape constraints and a single part doesn't meet your energy storage requirement and can't fit a larger single case, use two 450V parts in parallel instead.
Series capacitors, even with some high-value balancing resistors, require a bit of extra voltage derating so 2*250V is not actually 500V, a single 450V rated part is better.
Key to very long lifetime is,
1) using well known brands,
2) parts rated to 105 degC or more, and rated for some 5000 hours or more,
3) derating voltage and ripple current rating, maybe to 80% and 50%, respectively, if you can do that, that is,
4) derating temperature rating, i.e., make sure the local ambient doesn't go nowhere near the rated 105 degC.
Offline trobbins
« Reply #9 on: July 10, 2021, 12:12:51 pm »
"drying out" is also not the same as service life - do you have a description of what drying out means for the cap and the product?
Are you trying to prepare a design life or mtbf to quote in product docs?  Have you done a monte carlo on parameter changes that could lead to an out of spec product?  Are you providing maintenance data on what cap parameter degradation would indicate cap replacement?
Offline jonpaul
« Reply #10 on: July 10, 2021, 03:50:28 pm »
Bonjour, the rating you need is the temperature
85/105/135 dec C.
It gives the average part 2000 hours to decrease C 20% or increase ESR 50%.
Most cheap commercial parts are 85 C.
105 are better.
We used 135C caps from Rubycon, Nichcon etc that were for electronic ballst use in 1980s..1990s.
Ever 10 deg change in temp = 2x change in chemical activity.
Thus the 135 C caps are many time longer life.
Cap  internal temp = ambient temp plus ESR x RMS ripple current exp 2 (P=I exp 2 R)
Check any detailed lytic cap catalog for all the info and calculations.
Using two in series is seldom needed and increases cost and PCB footprint.
Bon Chance
Jon
Jean-Paul  the Internet Dinosaur
The following users thanked this post: pardo-bsso, Faringdon
« Reply #11 on: July 10, 2021, 08:57:19 pm »
The thing is, the 68uF , 250V capacitors have twice the ripple current rating as the single 33uF,450V capacitor.
As such, they will run cooler, and last longer.
(i admit it means more PCB space, but we accept that in return for longer lasting capacitance.)
In case anyone was wondering, we cant use two 33uF , 450V caps in  parallel as it would give too much capacitance, and too much inrush current.
Online bdunham7
« Reply #12 on: July 10, 2021, 09:18:21 pm »
Is there any reason you aren't looking at the EKXF451ELL330ML25S which would have a ripple current rating of 980mA @ 100kHz vs 1300mA for the doubled-up 68uF setup?  You'd have 5X derating vs 6.5X, but a 20k-hour specified life vs 12k.  Given those numbers, I don't think you can conclude that one or the other would last longer.
« Reply #13 on: July 10, 2021, 10:55:46 pm »
Thanks yes, you are obviously correct concerning those particular capacitor part numbers.....but, and i believe you would agree,  generally speaking it will be easier to find  68uF,250V caps with higher ripple current rating than 450V, 33uF capacitors. Also, i believe you would agree that it will also be possible to find 68uF,250V caps with just as much hours life rating as for 33uF,450V caps.
The only worrying thing about two electrolytics in series is if they get voltage unbalanced......but with two 250V caps in series across the mains rectified DC Bus, the difference in voltage could never get bad enough to overvoltage one of the 250V series'd caps.
There wouldnt even be any need for balancing resistors.
« Last Edit: July 10, 2021, 11:00:40 pm by Faringdon »
Online bdunham7
« Reply #14 on: July 11, 2021, 03:48:45 am »
What is the basis (evidence or theory) for this assertion?
Offline Siwastaja
« Reply #15 on: July 11, 2021, 08:28:40 am »
Look further, I'm sure you'll find a single part (or two in parallel) that satisfies your size constraints, ripple current and maximum capacitance requirements without series connection.
« Reply #16 on: July 11, 2021, 09:30:33 am »
Thanks, because its a capacitance voltage divider, and the capacitors are no more than 20% tolerance. The max bus voltage across the pair would be 373V. So with  two 250V caps in series, neither  is ever going to get overvoltaged
Thanks, Maybe there is some combination somewhere with parallel caps thats better...but it will be rarer than with series caps, and so we would get caught out with nil-stocks and production would get held up.
There is a Philips offline DALI  light dimming module (for use with streetlights)  that uses two 250V caps in series for the primary DC bus  (i took it apart,  ~3 yrs ago)....however, i cant remember if they used a resistor balancing network.
« Last Edit: July 11, 2021, 09:40:25 am by Faringdon »
Offline Siwastaja
« Reply #17 on: July 11, 2021, 10:01:05 am »
Capacitive voltage divider, by definition, works for AC signals. If the tolerances are good match, then this means they initially power up properly balanced thanks to being capacitive voltage divider indeed.
But after that power-on surge, they see DC over it. Now sustained balance is only defined by the leakage currents, and good luck finding leakage current tolerance specified!
Now in practice, elcaps leak more current near and slightly over the rated voltage so this mechnanism usually/likely keeps them balanced: one cap going slightly overvoltage "shunts" the charge, charging the other cap. And often the capacitors are not seriously damaged by this limited-current, limited time overvoltage. Hopefully.
But it's taking a risk as there are assumptions and uncertainties in this process, so avoid if you can. If you can't avoid it, do your due diligence.
Balancing resistors add a known "leakage" current which is highly accurate (because 5% resistors are cheap as dirt) and also follows a predictable I = U/R curve. Zeners/TVS would have much steeper curve.
« Last Edit: July 11, 2021, 10:06:25 am by Siwastaja »
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #18 on: July 11, 2021, 11:26:55 am »
Unless there is a reference for a study about disadvantages of series capacitors, I don't necessarily see a problem in this configuration other than what was mentioned before about balancing.
The ripple current will be equally applied to both capacitors (as they are in series) and obviously the weakest link would go down first (just like in an imbalanced set of batteries, where it is usual for one discharge faster than the others). With the calculated ripple and keeping the temperature low, the set will last for quite a while.
On the other hand, a case could also be made for a pair of 15 or 22μF in parallel, which will distribute the ripple current among them and take about the same space as two 68μF in series. So, it might simply be a matter of choice, really.
« Reply #19 on: July 11, 2021, 11:44:02 am »
Thanks, actually you are all correct.
The series capacitor thing is a gamble that we wont get widely disparate leakage current capacitors.....and i now dont think its a gamble worth taking.
The trouble with two 15uF, 450V in parallel is that  (generally) they will have worse overall ripple than one 33uF.
Online coppice
« Reply #20 on: July 11, 2021, 12:00:54 pm »
The caps that will last longest and the ones that are kept coolest. If two smaller caps can best be worked into a cool location, that will be best. If the single cap can best be worked into a cool location, that will be best.
« Reply #21 on: July 11, 2021, 12:17:46 pm »
True, but the ripple will be distributed over a much larger surface area, so the heating will be less.  You can also add a parallel 100-220n 630VDC polyester film capacitor in parallel as well, which will reduce the high frequency ripple a lot, and which likely will fit between the 2 15uF capacitors as well. You want to use a capacitor with a long life there, ripple current rating greater than your 200mA current draw, and if you want use an inductor to isolate the 2 capacitors from each other at high frequency, it will make the film capacitor and the one handle the HF ripple heating, while they both have the mains frequency on charging. But here capacitor manufacturer and temperature rating, along with rated life, is the determining factor, you want a good name brand in a series with a long life at 105, 125 or 135C rating, and to choose among them, and run the rest cool enough to give decades of service life.
Online coppice
« Reply #22 on: July 11, 2021, 12:46:41 pm »
In most designs failing regularly through dried out electrolytics, the proximity of a heat sink has far more influence than any self heating. Bad designers love nothing more than to bunch their electrolytics around the equipment's hot spots.
Offline Siwastaja
« Reply #23 on: July 11, 2021, 01:08:18 pm »
Sometimes you can't help that because it's conflict of interests, the capacitors are there in the first place to offer low-inductance (i.e., close by) supply rail for parts that require the current (i.e., heat up). They can't be far away.
Of course, you can often find a better compromise, and in some cases, i.e. "card edge damping bulk caps" not seeing much ripple, you could have placed them further away no problem.
Online bdunham7
« Reply #24 on: July 11, 2021, 01:54:40 pm »
True, but everything works together.  If this is an enclosed device, then you would also want the lowest total self-heating for any combination of capacitors.  Sometimes there is no cool location and you just need to improve the efficiency of the whole device.
