Author Topic: Phase Dimmer Control using Triac  (Read 1053 times)
Offline dinesh4761Topic starter
  • Country: in
« on: August 29, 2019, 09:59:53 am »
Hello Sir/Madam,
I am engineering student making phase dimmer control using triac
The schematic is as attached
What I have observed that many times attached circuit stop working due to failure of triac
I am not sure is it because of di/dt or dv/dt failure. In order to avoid this I have used triac of much higher rating (10A) even though current needed can be as low as 1A.
However the problem continues.
I have observed that the failure is for transformer powered halogen lamp (inductive load?) and for ceiling fans.
It works satisfactorily for incandescent lamps.
Also I am sharing one more observation that if I connect glass tube fuse link in series with the load then the fuse blows.
From the various information available I realized that I need to use choke / inductor to overcome this problem. Is that right?
I need help to
    1. To find out the value of the inductor for 0.5A, 1A and 2A
    2. Is this a special type of inductor? if yeswish to know make
Thank you in advance
Dinesh
Offline Kartman
Re: Phase Dimmer Control using Triac
« Reply #1 on: August 29, 2019, 11:59:12 am »
The choke (inductor) limits the rise of current which is highest at 90deg turn on. You want a core material that is lossy with high frequencies, like the Amidon yellow/white material. The actual inductance required depends on your current. Usually 200uH upwards. There’s plenty of info on the web to determine your inductance and selection of core size/wire size/current etc.
Using phase control for motors is tricky - due to the inductance the current zero crossing is different to the voltage zero crossing so you need to adjust your on  and  off timing carefully.
Offline Circlotron
« Reply #2 on: August 29, 2019, 12:07:26 pm »
What could be happening is if the conduction time of positive and negative half cycle are not exactly equal there will be some DC current flowing in the load. With a transformer or motor load they can easily saturate with the DC and then pull a much larger than expected current. This imbalance will not affect an ordinary light globe.
