You are kindly requested to propher your fave short circuit switch-off for mains. ie, 230vac mains gets a short circuit, and you want to switch it off. (short circuit from line to neutral)
Eg, back2back IGBTs in the neutral with a isolated supply feeding their gate drivers...and a comparator and sense resistor etc, to switch off the igbtS When sht cct occurs.
or
Overcurrent sensor and relay with relay snubber.
or
Back2back FETs in neutral.....and they are controlled for say 30A to 0A over some 2 seconds when sht cct occurs.
Whatever it is, it cant just be back2back FETs in neutral, then turn them off simply when overcurrent occurs..since FETs will explode if not "nannied" off with such high current and voltage cct.
