Author Topic: Massive reduction in SMPS undershoot and overshoot  (Read 741 times)
Offline FaringdonTopic starter
« on: February 08, 2023, 12:12:04 am »
Do you agree, what’s shown here is the future of SMPS? The attached shows a 120W Buck with very low output capacitance. (not needing to be electrolytic) However, even after a no_load to full_load transient , and vice versa, the output voltage does not go excessively high, and more importantly, does not go to zero , which may make microcontrollers reset etc.
Just unhook the overshoot and undershoot comparators and see how much worse it is.
This makes way for electrolytic capacitor free SMPS’s.
Do you agree, this paves the way for a paradigm shift in the world of SMPS?
'Perfection' is the enemy of 'perfectly satisfactory'
Offline Phoenix
Re: Massive reduction in SMPS undershoot and overshoot
« Reply #1 on: February 08, 2023, 02:14:31 am »
Nothing new in this idea. I've designed the control for a 50kW EV charger module with no electrolytic capacitors. It had a very similar high gain operation on the DC bus regulator that functioned only when the error was large.
The following users thanked this post: Faringdon
Offline uer166
