I'm quite tall indeed. But I used a socket wrench to tighten the clamps so I didn't need to reach all the way. Just enough to rotate the socket wrench a bit. Being a complete novice where it comes to laying solar panels (*), I didn't want to take any chances with the panels and took my time. I did read some manuals where it was strongly advised not to put any weight on the panels so I followed that advice. There probably is a grey area the professional installers know about intimately but I don't
We got all 27 panels installed, mainly following the plan I'd drawn up for the sequence to avoid issues trying to get access. I had a 22 nephew help me and he got the hang of attaching cable clips and routing the 1200mm long leads. For the row in portrait mode at the bottom we ran the leads down to the bottom so they could be connected after all panels were installed. For the upper portrait row the leads ran up the panel so could be connected at the top after placement. The panels at the outside of each 5x2 "block" had one lead up and one down so they could connect to the other row. The terminations to the home run cables for each block are at the inside edge (adjacent to roof window), with all leads running up.
I left a small (~25cm) access gap between the middle and top row which is 7 panels running in landscape mode so we alternated the panels here (+ve up, then +ve down) so the connections either ran along the bottom or the top, keeping the +ve lead always pointing left so this took a bit more figuring out.
The installer said to attach clips before we got on the roof so we did this on the scaffold where we could eyeball the location.
I'd preinstalled conduit with draw wires so this is now ready for the installer to come and do his magic sometime this week ready for the inverter which is two weeks away.
This is what it looks like on the house ...
And of course because I ordered a pallet of 36 and only used 27 on the house, I now have a "problem" of 9 spare panels. I've checked in with my wife and will order another 5 panels so I can fit 14 to the garage. This gets some shade which moves across the panels depending on time and season which would wreck the output of a string inverter so will look at optimisers or micro inverters for this.
And already strongly regretting doing the solar panel project so much that I don't want to go onto the roof again to mess with the solar panels.
Sorry to hear that, I've quite enjoyed it so far. A bit frustrated at times but a good opportunity to learn something new, and a challenge to get my fitness/upper body strength up a bit. It's 23 years since I was up on the roof when we built (I put the roof on with my Dad and father -in-law). Also I'm luck that the steepest part of the roof is less than 30 degrees and because it is curved it is only about 10 at the top so relatively easy to work on.
My nephew asked why we did not install solar PV when we built the house LoL. I had to explain that this system would have cost approx $100k back then so would never have been economic as power prices were 50% of current, so would have taken about 60 years for cash break even ignoring ROI. For comparison the full cost (excl garage) will be approx $15k, which I've modelled has a 5 year cash payback period, slightly longer if time value of money is included.
