So here is my scenario:
I have multiple Li ion cells in parallel, each with a buck boost (bidirectional) + INA219 for current and voltage measurement , each SMPS is tuned by a DAC so i have programmable 3-5V
all cells are separated by FETs , i also have a common rail for 5V in and another one for DC out.
I know how to charge the cells in CC CV mode but the discharge part is the problem for me.
How can i discharge more then 1 cell at .5A ( or wherever) into the output buss?
In my mind it seems doable since P=UI where U is set by the cell and I by me so P is limited in a way (this is for the input side of the SMPS)
As for the output it is again P=UI and P= delta P , here i somehow need to make all SMPS output the desired Power (since i need to have a set U, probably 4.5-5v since I need it to be higher then cell voltage in order for the IC to allow reverse current flow and this is a feature and not a hack since TI itself made a app note about this, for super caps), since P is tied to the other side then the only thing i can adjust is the current aka my load.
Note: yea there are loses and perfect .5A is not that important
And yes i am very careful with Li ion cells since i know that they are dangerous, that is why i am playing at low currents and only with 1 cell as of now
Am i on the right track? Or am i overthinking stuff and there is a much simpler way ?
