I must have missed it in the datasheet or misunderstood the context of your statement. What part of the description says that the Fairchild FAN9612 does not work with DC?
Just to clarify, I was looking for
examples that do or do not (definite rather than undefined) work on DC. Most are undefined; that was one which actually states it (positive definite).
I am dubious of this scheme using peak detection instead of RMS measurement (Is Fairchild avoiding a patent?) however it looks like they went out of their way to make sure it works with DC and modified SIN inputs. I suspect their peak detection method fails with high crest factor waveforms but that would be a very unusual operating condition.
AC, DC, funky waveforms, who knows... you can't win.
It would be pretty reasonable, at least, to expect that very quickly changing waveforms will have poor response (since the current loop can only react so quickly), but given that limitation -- a general approach should work with any waveform, frequency* and crest factor.
*Limited further by the voltage regulator loop, so you should avoid frequencies from almost-DC to 43Hz or whatever (else you get large output ripple, poor PFC, and poor regulation, because, what do you expect?).
So, these are the basic limitations we should expect from a general PFC. Anything that's further limited probably has a reason (be it patent evasion, design shortcuts, or good old fashioned laziness).
