Author Topic: Problem Li-Po battery  (Read 1221 times)
Offline tiago1986Topic starter
« on: June 11, 2021, 10:11:12 am »
I have a handheld handheld console but something strange happened to me twice, I kept the device turned off with the xiaomi BM20 battery inserted and both times after a period of non-use (maximum 2 months) when I went to use the device the battery was swollen swollen, what could be happening? if I store the BM20 outside the device it does not swell in the stove but it is very annoying to keep putting and removing the battery from the device
Re: Problem Li-Po battery
« Reply #1 on: June 11, 2021, 10:45:37 am »
I bought several BM20 batteries on Aliexpress the same from the same seller but they only swell if they are inserted in the device for a long time without use he said they are original and their value is high, they had a voltage of 4.1v
« Reply #2 on: June 11, 2021, 10:46:37 am »
device is handheld Powkiddy Q80
Offline Siwastaja
« Reply #3 on: June 11, 2021, 10:52:39 am »
The aliexpress cells are just crap and possibly dangerous. Don't waste your money on them.
« Reply #4 on: June 11, 2021, 10:59:05 am »
Where can I buy the original BM20?
the strange thing is that this battery swells only inside the device turned off and not plugged into electrical power
« Reply #5 on: June 11, 2021, 12:11:29 pm »
I do not know the protection circuit of the device is a handheld handheld Powkiddy Q80 console but it was purchased with the battery already installed and it did not swell but the original batteries I bought both bulged inside the console with it turned off
I just updated the console firmware
« Reply #6 on: June 12, 2021, 10:22:19 am »
I'm thinking about purchasing an imax B6 mini universal charger to charge/discharge/storage mode some Li-Po mobile phone batteries BM20 and BP-5L models but I don't know which adapter I can buy to make this operation possible, there is an adapter for do that? I think about buying on Aliexpress
