Hello,
Capacitor reforming is a common, but often overlooked problem of electrolytic capacitors.
You just let an electrolytic cap sit unused, without voltage for some time, and the cap deteriorates chemically.
When using it again, it exhibits "some" leakage, the time to re-plate the oxide onto the foil surface, and all is good again.
This leakage often is overlooked in the normal device inrush current that nearly all SMPS show.
Problem is that this inrush can become very huge, and explode the cap, blow the fuse, etc etc ...
Often it is overlooked, because it's an uncommon problem of untypical users that store the gizmo for a long time.
Some uses are more prone to this problem, but basically all are affected, and cap manufacturers often don't put a guaranteed value in their datasheet.
Time to change this, and measure and publish a list of better caps that don't need so much reforming.
https://www.quadplus.com/post.aspx?PageID=224I recently got a few hundred 400V electrolytic caps that are brand new but unused because it was found that they exhibit unusually high breakdown of the oxide, and need frequent reforming.
It could be a defective batch, or a bad chemistry choice altogether... The brand is an usual "questionable" manufacturer of caps.
These can show a reforming effect after only 1 month without voltage.
If enough people are interested here, I will develop and distribute a simple test tool for measuring the characteristics of the caps you use concerning reforming, and demonstrating the reforming effect to your manager or your students.The idea :
- Small PCB regrouping the necessary hardware, to make the test setup fast to use
- Rectifier
- Current and voltage measurement with scope
- Simple slow controlled reforming with a high value series resistor from mains (useful also for reforming any equipment)
- Simple fast reforming with a very low value resistor (simulating a user just plugging the equipment to mains, with high current)
- Eventually a microcontroller with a coulomb counter and display for measurement
- Eventually a protected transparent housing
- Open source HW
- Of course, Included in the kit : 5 to 10 "bad" caps -> capable of demonstrating the reforming effect once per month each
Please vote, and make suggestions !
