Author Topic: Re-use old 18650 cells  (Read 2327 times)
Offline gpointTopic starter
« on: August 08, 2022, 02:29:04 am »
Hi there,
Hope to get some gurus here to have a discussion.
We have purchased a few new dyson V6/V7 battery packs to replace our old ones. Some of the old battery packs were still not "fully dead" after a few years usage, they still lasted couple of minutes to run the vacuum cleaner. An idea came to my mind, why not re-use the old battery packs for my ebike (i don't need large capacity for the bike for my short distance travelling) rather than dumping them.
Hence, I took out the battery pack, each 21v, and i put two in series to make up 42v for my 36v eBike motor (Many many thanks to tinfever from this forum who provided me the excellent information to activate the BMS by putting a magnet next to the switch!!!). I did some searching and found that my 36v ebike motor can take up to 52v input. So there it went.
I did a bit of soldering of connectors and hook it up to the bike and gave a go yesterday afternoon.
And guess what? It ran like a charm at the beginning (i could feel more powerful than my original 36v eBike battery)!
But but... After about 3-4km, I smelled burning/sulphur from the battery packs! That was really scary to me, i quickly got off bike and unplug the power cable, and felt the battery was just normal warm by hand. Then i got on the bike again for another 3-4 km, same smell again, I had to stop using for my scary heart.
I am not a lithium battery guru, any suggestion/discussion are really welcome and appreciated.
Could it due to the ebike motor withdraws much higher current than the handheld vacuum cleaner? But if that's the case, the BMS should have kicked in to cut off?
PS. i feel that if i don't aggressively pressed the throttle (i mean pressing for long time), it seemed that the current didn't go with over-drawn.
Thanks in advance.
Offline Siwastaja
Re: Re-use old 18650 cells
« Reply #1 on: August 08, 2022, 12:19:31 pm »
Cells are possibly running very hot, maybe plastics / tapes / whatever around them are giving the smell. The 18650 cells Dyson uses definitely will have some passive safety built-in, but it's not a good idea to rely only on that. 18650 PTC cap tends to trigger around roughly 100degC surface temperature.
What could the BMS do? You have not added temperature sensing to the cells, after all.
Second-life use is always problematic, but it's especially problematic for relatively large discharge currents, because aging mechanisms usually hit the internal equivalent DC resistance more than it hits the capacity. For example, End-Of-Life is often defined as 30% capacity drop, or 100% DC resistance increase, whichever comes first. Old cells that have half the capacity left may easily have 2-3 times the DC resistance. In other words, the fact a vacuum cleaner is only running for say 6 minutes instead of 60, does not mean there is 10% of capacity left; it can also mean internal DC resistance is so high that low-voltage cutoff limit is met after discharging only 20% of the capacity or so, because of the U = R*I drop of the cell! But these cells could perform just fine in low-current application.
Therefore, I would not try to use aged cells for loads that need more than say 0.2C average current or 0.5C peak current.
"Small old pack is fine because I only make short trips" is actually the worst case, because that implies high current relative to the battery capacity.
And, of course, I cannot recommend doing any of this at all, so always remember there is a risk involved.
The following users thanked this post: gpoint
Offline geggi1
« Reply #2 on: August 08, 2022, 07:05:47 pm »
Diffrent battery cells are made for diffrent use.
If you look at LIPO batteries used for RC stuf you will see that they have very high discharge durrent.
For your Dyson cells this might be cells made for lower discharge current.
« Reply #3 on: August 08, 2022, 11:43:33 pm »
Thanks for the input.
Yeah, it could be the reason.
I checked the specs of the eBike controller, it says normal 10 amp with a maximum of 15+-1 amp. And it was a bit of slope when it had the burning smell.
Anyway, that was a good try to know that the battery packs are almost dead, although it outputs a good voltage but running out in short time.
Cheers.
Offline thm_w
  • Non-expert
« Reply #4 on: August 09, 2022, 12:30:18 am »
From the photos I can find, dyson V6 is using 6 18650's in series, 1P S configuration. https://www.18650batterystore.com/en-ca/products/sony-vtc4
They are actually really high drain cells at 30A. At peak the dyson might draw around 14A. So not far off from the bike.
But as Siwastaja says it probably doesn't make sense to use old cells like this, their performance can be severely degraded. Unless you've actually verified they are still good capacity/esr/etc.
« Last Edit: August 09, 2022, 09:13:07 pm by thm_w »
Offline Siwastaja
« Reply #5 on: August 09, 2022, 06:19:47 am »
Sony VTC4 is good for a 15A max motor controller when in pristine condition, but I would not use End-of-Life cells beyond say 2-3A, even if they are high power cells originally rated to 30A(peak).
Offline grizewald
  • Country: ua
« Reply #6 on: August 09, 2022, 03:05:33 pm »
From the photos I can find, dyson V6 is using 6 18650's in series, 1S configuration.
Six cells in series would be a 6S1P configuration.
  Lord of Sealand
« Reply #7 on: August 10, 2022, 11:29:41 pm »
Agree. I won't use it for normal riding (may just use it occasionally to ride with young kids sounding our house when i feel tiresome).
Then i just realized the smell may not be from the battery cells, it may be from the wire i used, coz i didn't have 15A rated wire at hand, just chucked in a 10A rated instead.
The other thing we found is that Dyson may not necessarily use the best cells (from the price of Dyson product, initially i thought they used the high end cells).  ;)
Offline james_s
« Reply #8 on: August 11, 2022, 01:40:12 am »
I'm all for reusing things, but I would be looking for lightly used but obsolete battery packs to salvage cells from, not well used ones. If you do want to reuse the tired cells, they are handy for powering various things on the bench. A 3.3V LDO and a single 18650 cell can be handy for powering small projects and there are many flashlights that take them.
Offline Psi
« Reply #9 on: August 11, 2022, 01:56:02 am »
Could be a few different things.
If you can borrow a thermal camera it may help to narrow down where the problem is.
« Reply #10 on: August 11, 2022, 06:07:22 am »
Good idea!
I think of camping lights!  :) :) :)
Offline f4eru
    • Chargehanger
« Reply #11 on: August 11, 2022, 06:54:30 am »
Just a theory:
It could well be that the dyson batteries are actually air cooled by side effect of the air inlet for the fan purposely routed through the pack, in their normal use.
Old batteries tend to have higher series resistance, hence will heat up more, especially when taking high currents, as in an e-bike.
The current you pull out is probably at the edge of the cell's capability for sustained use, could be in the region of 4A.
Reused cells shoulds be used in less demanding applications, if at all.
Offline grizewald
  • Country: ua
« Reply #12 on: August 11, 2022, 09:21:20 am »
Just a theory:
Given the tendency for old cells to overheat when abused and the unstoppable nature of Li-ion fires once they start, I prefer not using old cells at all. While it is true that modern cells are much safer than they were, I cannot know what kind of treatment used cells have been subjected to, particularly those without any inbuilt over/under discharge protection. Once a cell has been damaged, then even charging it can be risky.
It's one thing having to quickly abandon your e-bike if a cell fails while you are outside using it, but having a cell fail while you are at home charging the pack can burn your house down. The risk is much greater with LiPo packs than with 18650 cells, but even so, charging lithium batteries unattended is a risky proposition at best.
  Lord of Sealand
« Reply #13 on: August 12, 2022, 06:21:20 am »
I think that is the BMS there for.
A good BMS should be able to monitor the voltage/current/temperature all the time no matter charging or discharging.
