You can make your own tool using something like MS Excel, and using the many reference books on-line. That's what I did 20 years ago, but it preferably integrates the SCR's and diodes and heatsinking you can access, and the type of transformers and chokes you can access, and what contoller/driver you can use, and what protection parts and settings are needed, and uses your experience on what the appropriate rectifier configuration would be for starters. You would need to confirm the ripple requirement, and what the operating environment would be. There is a lot to go into a commercial product, so hopefully you are not thinking of starting from scratch, as it took me quite a while and that was having access to more than 50 years of experience and projects for assistance.
