Many GD transformers have 5-10 pF CM capacitance or more, sometimes much more. This would give ~3 A (!) of CM current from secondary to primary.
Thanks for bringing this up. I know what you mean.
But if i put in values of
Stray C (interwinding) =10pF
dV = 400V
dt = 20ns
...then it gives i = C.dv/dt = 0.2A.
I wasnt sure where the 3A figure came from?
GDTs do have problems as you discuss, i agree, and they always have significant stray interwinding capacitance because they usually must be wound for low leakage inductance.
However, scores of lierature speaks of the severe problem of bootstrap chips when the input voltage is at say 400V (PFC output).
Dr Basso mentions bootstrap problems in his book.
Dr Ridley also speaks of the dangers of the bootstrap negative going voltage.
Pg 16 of this..
https://www.onsemi.com/pdf/datasheet/ncp5106-d.pdf...speaks of the terrors of the bootstrapper.
Dr Ridley speaks of the terrors of the bootstrap chips here...
https://ridleyengineering.com/design-center-ridley-engineering/49-circuit-designs/192-a11-gate-drive-design-tips.html...and in this document, Ridley states how the GDT offers the most rugged hi side drive solution when voltage is around 400V or so.
We cannot point to interwinding capacitance of GDTs as a massive problem, since all GDTs will be either interleave wound or bifilar wound (to reduce leakage inductance), and so will have very significant stray interwinding capacitance, yet Ridley still says its the most rugged hi side drive method when voltages are ~400V.
Thanks Zero999, the ADum5230 is indeed a superb solution to this, but pricey and a nil-stock-worry.
