Yamaha V685 used as a preamp only. Dynaco ST-70 driving a pair of Altec Lansing A5X VOTTs.
Matters not what I’m listening to. Happens with no program selected. Preamp on or off. Volume muted or not. All light switches, flat screen TV powered on or off makes the pop. Those are all on the same CB, but the AC compressor is not and it is the worst. So it is the tube amp that is picking it up. I can change receptacles but still the same CB. Going to get a long extension cord so I can be on a different CB but with the AC doing it I don’t expect a difference.
Thanks,
Jeff
