3. You are mixing switching freq. and MOSFET turn on time. They have noting to do with each other. (in this case)
Thanks, as you know, if the turn on time is long ish, but the switching frequency is low...then this kind of helps, as the lower switching frequency lowers the switching loss.
As you know, slow drain transistion time helps common mode emc.
