Thanks, and BTW, the Flyback that produces 300V from 12V, wont need to go +300,-300.+300....etc...it will only need to go from +300v to 0V to +300V.... repeatedly, (small dead time at 0V) because that gives the periodic zero current so that it doesnt have trouble with "DC fusing".
So no need for AC at all.....just DC pulsating....and use an cheap AC fuse, because current goes periodically to zero Amps....every 10ms or so, or 20ms or so, whatever you want.
As you can see, this is far simpler than an inverter.
