Author Topic: Solar panels as a sun screen  (Read 490 times)
Online nctnico
« on: August 21, 2019, 06:03:21 pm »
I'm wondering about how effective solar panels are as a sun screen. Has anyone with solar panels on the roof noticed a significant improvement in keeping the heat out of the home after installing solar panels?
Offline Seekonk
Re: Solar panels as a sun screen
« Reply #1 on: August 21, 2019, 06:19:50 pm »
Solar panels make great outdoor patio covers. The trend now is to have very close fitting panels to the roof for cosmetics with very little air space. Neither good for the house or solar production due to heating. It doesn't matter because most people in solar are morons.
Offline bdunham7
« Reply #2 on: August 21, 2019, 07:31:12 pm »
I actually checked this after mine were installed because roof and attic heat is a big deal here.  The inside of the roof stays cooler a little longer when the sun starts, but by noon I couldn't tell any difference and the attic was as hot as ever.  So while I'm sure it helps, it didn't seem significant.  My panels are about 6" off the roof.  If there were 100% coverage and ventilation under the panels, I'm sure that would make a difference, but I only have about 15% of my roof covered in panels.
Offline john61ct
« Reply #3 on: August 21, 2019, 07:32:11 pm »
The heat output radiated out the back of the panels from the PV process is enormous.
Need an airgap so convection removes that radiated heat output, for PV efficiency as well as reducing heat gain into the roof space.
Dunno about Tesla-style "tiles" though.
Offline ahbushnell
« Reply #4 on: August 22, 2019, 01:30:57 pm »
Your comments made since except where did the last sentence come from?
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #5 on: August 23, 2019, 07:42:28 am »
My house was just as hot after installing panels and i have as much as i can have by law in coverage.
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear and Wurth Elektronik Books.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Online nctnico
« Reply #6 on: August 23, 2019, 09:13:13 am »
Thanks everyone for replying and thinking along!  :-+
That doesn't sound like a solution then. I can cover about 50% of my roof surface because of the various obstacles on the roof and the size of the (cheap second hand) panels I have found.
