How does electrical billing work there? We got net metering just in the nick of time. It's gone away in California. We have 27 kW-hr of batteries because I'm concerned about grid stability here. Without EV's we can make all of our power. We have two EV's now so that requires us to pull off the grid.
The provider is forcing me to get a smart meter, which presumably puts me on a time based pricing system. Currently it's fixed.
Grid stability is simply not an issue in Sydney.
They should be able to tell you which tariff you'll be on. Just because you switch meters, surely they can't just force you onto time-of-use?
I deliberately wanted to switch over to time-of-use (I only pay peak pricing between 1600-2000hrs weekdays, all other times are off-peak) and it was a nightmare that took many months. I first had to get a smart meter, that was step one, but then when I did, Energy Australia just went "computer says no". Eventually the energy distributer fixed it and I was able to switch to another retailer that offered time-of-use rates. I was warned however, once I switch to TOU, I can't switch back to a fixed rate.
Ultimately, on any reasonably sunny day, I don't pay anything during peak time at all. On really cloudy days, my batteries are configured to charge off the grid between 1400-1600 to get them to 100% so I can offset the higher cost of power later in the day if the solar isn't doing much. I'm saving a significant amount by switching to TOU, which is currently 25.5c/kWh (including GST).
