Author Topic: This solar farm has to switch off every second day due to negative prices  (Read 535 times)
Online BBBbbb
  • Country: cs
https://reneweconomy.com.au/this-solar-farm-has-to-switch-off-every-second-day-due-to-negative-prices-63529/
Some thoughts:
- This could be a great tool to penalize the non-green sources (coal, gas) that can't switch off on the cheap, and end up getting hit by the negative prices.
- OTOH these agreements are confidential, and since the non-renewable sources can provide stable and weather independent supply they could easily negotiate a lot better conditions, meaning no negative prices, so without sufficient "hydro batteries" I doubt the pressure is meaningful on non-renewable sources
The following users thanked this post: ahbushnell
Offline Marco
Re: This solar farm has to switch off every second day due to negative prices
« Reply #1 on: November 07, 2019, 03:28:00 pm »
Time to mine and refine more aluminium.
The following users thanked this post: ludzinc, BBBbbb, Jacon
Offline bdunham7
« Reply #2 on: November 07, 2019, 05:59:11 pm »
There's nothing surprising or wrong about this.  Obviously with a zero incremental cost, the solar plant would like to sell all of the electricity it can produce, but there will never be an exact match between capacity and demand.  When the price of the commodity goes below the cost of production, you turn the system off.  Since the only way you can have sufficient production all or most of the time is to have surplus capacity, it seems obvious that at times some capacity will not be needed.  When solar was a small part of it, other non-zero incremental cost producers would drop offline first. As solar and wind become larger, curtailment will become the normal process for managing the grid.  At least it is easy and quick to turn on and off!
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: November 07, 2019, 06:06:02 pm »
It would be interesting actually to put it into an aluminum battery of some sort.  Unfortunately the Hall process demands continuous operation at scale; indeed, it's usually run on hydro.
Aluminum electroplated out of some kind of organic carbonate solution (analogous to getting lithium metal out of an overcharged ion cell) would be interesting, though I wonder if it could end up anywhere near economical anyway.  (And in any case, energy storage is better with alkali metals, no need to try and sell an already quite cheap industrial metal out of it, etc. etc... ::) )
Seven Transistor Labs, LLC
Offline Syntax Error
  • I took the red pill...
« Reply #4 on: November 07, 2019, 06:20:42 pm »
Any engineers know of a way of converting CO2 into a solid? This would be a rather green way of using the over capacity by directly or indirectly removing atmospheric CO2 and then, selling this carbon capture on the global carbon trading market. Yes New South Wales, you can tax that. Maybe even make hydrogen for fuel cells? Or just mine Bitcoins on 'negative' electricity days? Otherwise it's a tragic waist of sunlight.
Help reduce e-waist and reflash your old router with OpenWRT.
Offline coppice
« Reply #5 on: November 07, 2019, 06:29:11 pm »
Most aluminium used to be produced in countries with surplus hydro power. Look at the global production figures now, and you'll find most aluminium is produced in China, where there is a massive shortfall in renewable power. They are the world's biggest installer of renewables, but they have a long way to go to wean aluminium production off fossil fuels.
Offline ejeffrey
« Reply #6 on: November 07, 2019, 07:30:08 pm »
It is pretty hard and energy inefficient to remove CO2 from the atmosphere as the concentration is so low.  For the forseable future it is much more advantageous to remove it from waste streams where the concentration is much higher.
In terms of fixing CO2, there are basically two options: 1) carbonate minerals.  This is attractive because it doesn't require massive energy input.  This is how geological carbon sequestration works. The downside is that you have to mine a ton of uncarbonated minerals.  We actually mine carbonated minerals (calcium carbonate) and extract the CO2 in order to produce quicklime.  2) hydrocarbons.  This doesn't require any particular mining, but again we currently mine hydrocarbons and burn them, so this doesn't make a huge amount of sense to do the reverse process.
Online daqq
  • Country: sk
    • My site
« Reply #7 on: November 07, 2019, 07:43:09 pm »
Not sure about solid, but carbon capture is a thing. Don't know how efficient it is.
http://www.climeworks.com/our-technology/
Online Retep
« Reply #8 on: November 07, 2019, 07:45:39 pm »
Grow a tree?
The following users thanked this post: NiHaoMike
« Reply #9 on: November 07, 2019, 08:55:28 pm »
Grow a tree?
Isn't photosynthesis clever? This might work as a concept if the excess electric is used to power pumps to irrigate crops or even a forest. But then where does all the water come from in a desert where solar farms are often located?
Sucking air through carbon eating filters might work, but I doubt there are economies of scale when you calculate how much C02 is produced making the fans in China or India. Idea for a Kickstarter/Snakeoil project; fit carbon eating filters on all kinds of extraction fans around the home. A million dollar$ please.
--etc--
Agreed. I wonder if they'll ever worry about the levels of CO2 on Mars?
It's a crying shame that all of his sunlight goes to waste, but that's just the "the market" for you. Expecting governments, state administrators, industry and private venture capital to use joined-up-thinking to mitigate climate issues is not going to happen anytime this century.
Offline chickenHeadKnob
  • doofus programus semi-retiredae
« Reply #10 on: November 07, 2019, 09:01:30 pm »
The other chemical pathway for energy storage is Ammonia. Ammonia can be burned, or put through a fuel cell or sold as fertilizer in liquified anhydrous form. Farms could be made entirely self powered.
Offline NiHaoMike
    • Facebook Page
« Reply #11 on: November 08, 2019, 03:18:23 am »
A reasonable way to make use of the "extra" energy is to pass through the savings to customers. A large part would be to leverage existing thermal mass as storage, e.g. set water heaters to a higher temperature, run HVAC equipment more, set freezers to minimum temperature.
« Reply #12 on: November 08, 2019, 12:27:00 pm »
In Canada I think this already being tried in a small way, I heard Nova Scotia or PEI has some kind of smart water heater program but I live on the opposite coast so not sure.. It is easily implemented with an IOT controller that checks in with the power utility  and requires very low incremental infrastructure costs. Easy win.
Offline DenzilPenberthy
« Reply #13 on: November 08, 2019, 02:10:29 pm »
I don't know about using excess power to remove CO2 directly but there are plants using excess power to generate hydrogen which is then fed in to the gas grid.
https://en.wikipedia.org/wiki/Power-to-gas
Offline Marco
« Reply #14 on: November 08, 2019, 04:44:52 pm »
Everything needs to be kept molten, but that can probably be done with far less power than electrolysis itself. The plants weren't designed with as hugely varying power costs as we have nowadays, there is obviously huge inertia given the capital and R&D investments involved but I expect intermittent plants at some point. Even if none of the alternative reduction methods bear out.
It's solidified electricity, if you can make it and even get paid for the electricity you're consuming you're golden.
« Last Edit: November 08, 2019, 04:48:58 pm by Marco »
Offline Someone
« Reply #15 on: November 08, 2019, 10:20:40 pm »
This is significant "low hanging fruit" in the possible ways to develop demand responsive grids. Various sources claim HVAC alone is a significant part of the total energy demand so its not like the well funded yet minimally effective efforts to change to high efficiency lighting. Sadly very few customers are exposed to the wholesale market so many efforts so far have been by pooling resources through a wholesale market participant, who acts as a middle man and takes all the profit.
More encouragingly energy for heating is dominated in "developed" countries by low temperature demand which is easier to deliver/store or simply produce at low cost from renewables. Long term storage is still more expensive than oversizing the generation capacity there, so market fluctuations with negative cost periods are probably a healthy sign.
Offline Marco
« Reply #16 on: November 08, 2019, 10:57:01 pm »
Easier to store, yes. Easier to deliver, hell no. Only a small subset of houses have district heating, they pretty much all have electricity.
Offline Someone
« Reply #17 on: November 08, 2019, 11:14:38 pm »
Note the conjunction:
Store and deliver, as in deliverable. Delivering low temperature deltas is much easier, particularly from local thermal storage.
