Author Topic: Too Many Amps?  (Read 456 times)
Offline Rickyroller5
Too Many Amps?
« on: August 23, 2019, 02:02:30 pm »
I have a Lepai audio amplifier that requires a 5V, 2A  DC input "wall-wart."
Can I use a 5V, 3A unit without damaging the amplifier?
Offline Kleinstein
Re: Too Many Amps?
« Reply #1 on: August 23, 2019, 05:09:05 pm »
The input specs of appliances is usually the maximum current they use, or the minimum current the power supply should be able to deliver. So the power supply should be at least 2 A, a more powerful supply is not a problem. A 3 A supply is absolutely fine.
I would just be careful if more than some 20 A, if there is no suitable fuse in the supply. It would not damage the amplifier, but a short at the cables from the supply could cause a mess.
The following users thanked this post: NiHaoMike
Offline David Hess
  • DavidH
Re: Too Many Amps?
« Reply #2 on: August 23, 2019, 05:25:23 pm »
Yes, the current rating represents the maximum available current but the load will only draw the necessary current.
Offline john61ct
Re: Too Many Amps?
« Reply #3 on: August 23, 2019, 09:57:05 pm »
Yes, 300A or 3000A doesn't matter.
More is fine, less is not.
