Author Topic: Unknown device in HV transmission installation  (Read 1157 times)
Offline eblc1388
« on: September 26, 2021, 07:43:24 am »
The picture is taken from a HV outdoor installation somewhere in China. What is the name and purpose of the circled device mounted under the corona shield on top of the bushing?
« Last Edit: September 26, 2021, 07:46:53 am by eblc1388 »
Offline bob91343
Re: Unknown device in HV transmission installation
« Reply #1 on: September 26, 2021, 04:41:51 pm »
Maybe just a warning siren, unrelated to the high frequency stuff.
Online NiHaoMike
    • Facebook Page
« Reply #2 on: September 26, 2021, 09:03:39 pm »
Might it be a microwave horn for some sort of wireless sensor?
Offline f4eru
    • Chargehanger
« Reply #3 on: September 26, 2021, 10:17:25 pm »
could it be an E-line launcher, with the outgoing wire not yet mounted ?
http://corridorsystems.com/FAQ.html
Love High Voltage  :scared:
« Last Edit: September 26, 2021, 10:38:23 pm by f4eru »
Offline AlbertL
« Reply #4 on: September 26, 2021, 10:19:22 pm »
It appears to be directly connected to the high-voltage line, so I don't think it would be anything like an antenna or sensor that would require power or signal wiring.  My guess is that it's a contact or receptacle for a jumper cable or disconnect/isolating switch.
Offline AlbertL
« Reply #5 on: September 26, 2021, 10:23:14 pm »
Agreed, it sure looks like that's what it is.  Interesting technology - kind of like a Goubau line apparently.
Online NiHaoMike
    • Facebook Page
« Reply #6 on: September 27, 2021, 01:09:00 am »
I'm thinking it could be a sensor that's powered by energy harvesting the electromagnetic fields and the wireless link is specifically a way to cross such a large voltage difference.
Offline eblc1388
« Reply #7 on: September 27, 2021, 09:06:26 am »
Thanks all for your inputs.
@NiHaoMike,
The picture was captured from a Youtube video mentioning power shortage in China.
Your explanation appears to be the most plausible so far. Judging from the many stacks of HV bushings, the voltage could be 1000KV or higher. The horn of the device seems tilted up at a particular angle to enable the transmission of both power and data to and fro. I believe it is a sensor of some sort, and is powered by incoming microwave energy while also sending back data.
Offline f4eru
    • Chargehanger
« Reply #8 on: September 28, 2021, 09:17:42 pm »
Yep, I agree. It`s clearly part of the power path, that seems to finish here. So it could very well be a half of a disconnect switch, a self centering receptacle, with the other half outside the picture (male contact with moving frame).
The torus on top and bottom is the electrode for catching the arcs when switching.
something like this ?
https://www.gegridsolutions.com/products/brochures/spol_ansi-brochure-en-2019_01-grid-ais-0077.pdf
When  engaging
the  fixed  contact,  the  mobile  arm  enters
the guiding bell
« Last Edit: September 28, 2021, 09:25:54 pm by f4eru »
Offline AlbertL
« Reply #9 on: September 29, 2021, 02:22:22 am »
When  engaging
the guiding bell
Yes, the drawing on page 2 which shows the guiding bell, which looks just like the device in the original photo.
Offline eblc1388
« Reply #10 on: September 29, 2021, 05:00:27 am »
AlbertL and f4eru,
You've convinced me that the device is part of the disconnecting switch stationary contact. I have re-examined the photo I posted and discovered a similar device at the middle of far right edge. Also in the Youtube video where the screen capture is taken, at time 1:52, a tower is seen at the right of this bushing stacks. It is very likely that the moving contact of the disconnecting switch is connecting the power to an overhead line at a greater height.
Youtube Video:
The following users thanked this post: fourtytwo42
