Has anyone considered using a volume of water (well water/gylcol mix) as a dynamic heat sink for a system using a heat pump?
A 1000 litre IBC is cheap, could be buried in a pit, insulated with some normal insulation, and with a heat pump arranged to be able to heat or cool that volume, would be a significant energy store, enabling dynamic load shedding espically wrt to cheap grid energy / solar power?
1000 litres of 70/30 water glycol is 1057 kg, has a specific heat of 3.74 kJ/kg.K, and with a heat pump using a refrigerant to coolant exhangers to avoid icing (no ambient air containing moisture to freeze up) and probably avoiding boiling too (makes system simpler as it won't have to be a pressure vessel) could probably operate with a 90 degC deltaT if necessary on that coolant store. That means around 100kWh of energy can be dynamically exchanged.
I live the UK, where we tend to have cold nights, and warmer days, and our solar load is very peaky, and our grid electricity costs are highly industry demand driven, and recently have been going negative overnight!
So, in the winter, when i say want to heat my house for 6 hours in the evening (4pm to 10pm) i can use a cheap solar hot water array on the roof to heat the coolant store, and if that is insufficient (which it will be for most of the winter) then i can turn on electric immersion heating during cheap rate electricity the night before.
In summer, if i want to cool my house (increasingly required as our summers get hotter) then i can simply reject heat from the house into the coolant store, and over night, when it's cooler, use a simple cheap air/water radiator to reject that heat to ambient air, over a longer period.
This, at first glance seems a sensible system, and relatively cheap, using a heat pump to move heat around, and cheap components that could certainly be sourced (sic) second hand in order to build it?
By leveraging a heat pump, the energy i ultimately pull from the grid can be around 3 times lower than the heating/ cooling power, and of course, it would be possible to move that to a solar electricity based system eventually....
Have i missed something important here? I'd have to run a simulation over a typical UK year to see how it stacks up i guess
