Author Topic: Do someone still use big NiCd at home/work for solar storage?  (Read 2912 times)
Offline MiyukiTopic starter
  • Country: cz
    • Me on youtube
I have a possibility to buy big NiCd battery (120Ah cells) for almost no price should be at 75-80% capacity
I want to ask if someone have experience with it ?
Online NiHaoMike
    • Facebook Page
Re: Do someone still use big NiCd at home/work for solar storage?
« Reply #1 on: April 19, 2018, 02:33:15 pm »
Do you have a way to test it first? NiCd is a very forgiving chemistry, even more so than lead acid. What I'm not sure about is disposing of it when it finally does fail, since it's hazardous waste just like lead acid, but I don't think auto parts stores would accept large used NiCd.
  • Country: cz
    • Me on youtube
« Reply #2 on: April 19, 2018, 02:44:06 pm »
Disposing is not a problem here as here is still manufacturer and buy them back for a few cents per kilo  :-+
What is best way to test them at first ?
I can buy 89 of 120Ah cells so it will be lot of cells to inspect
Offline james_s
« Reply #3 on: June 04, 2018, 03:40:06 am »
If it's really cheap just grab it, if nothing else it should be fun to play with. I use a deep cycle lead acid battery to power an inverter during power outages, a big NiCD battery would offer higher energy density.
Offline David Hess
  • DavidH
« Reply #4 on: June 04, 2018, 09:33:01 am »
If these are flooded cells then you should be able to check the electrolyte (potassium hydroxide) level and top it off with distilled water and they are practically indestructible; only flooded nickel-iron cells are tougher.  They would be fabulous for off-grid solar storage if you can find a suitable charge controller.
Offline james_s
« Reply #5 on: June 04, 2018, 06:28:54 pm »
Flooded NiCD? I don't think I've ever encountered such a beast, what are they used for? Aircraft batteries?
Offline David Hess
  • DavidH
« Reply #6 on: June 04, 2018, 07:17:46 pm »
Aircraft and military applications were common because they have a wider operating temperature range, are more rugged, and perform better than lead acid batteries.  Flooded cell NiCd were also used in traction and backup applications.  Lead acid batteries are cheaper but do not last as long.
They still make them for demanding applications:
http://www.sbsbattery.com/products-services/by-product/batteries/nickel-cadmium-batteries-1.html
http://www.advancedbattery.ca/content/alcad-flooded-ni-cd
Offline james_s
« Reply #7 on: June 04, 2018, 08:55:01 pm »
Those are neat, they look very expensive though.
Offline David Hess
  • DavidH
« Reply #8 on: June 04, 2018, 10:54:30 pm »
They were more expensive than lead-acid for a given energy storage but less expensive once service life was taken into account because they last so much longer.
