As we know, Offline SMPS’s get tested for high voltage withstand between their primary and secondary sides. The test involves the application of a certain voltage, for a certain time, and during that time, the leakage current between primary and secondary must stay below x milliamps.
How the test voltage, length of test time, and leakage current is calculated is completely unknown.
Its not possible to calculate these things, and if you want to know such things, then you must purchase expensive standards documents. The number of standards documents that an engineer would have to purchase in relation to an offline SMPS development, is a great many…and no engineer could possibly afford to buy all these standards. The company that an engineer works for will not lend out the standards documents to any engineer, -because if a product gets shipped without passing one of the standards, (which they so often do) then the company doesn’t want people knowing about it…so keeps their own standards documents to themselves.
Sometimes the “Hi-Pot” test voltage is AC at 50Hz, and sometimes its DC.
Its impossible to calculate what [DC test voltage /Test Time /Leakage current] corresponds to what [AC test voltage /test Time /Leakage current].
But , ….supposing you do know that your product must pass "2500VAC for 1 minute, and the leakage current must stay below 3mA for that one minute"…
Then you pick up a Hi-pot tester and set it to 2500VAC….and you count to 60 seconds and hope that it doesn’t flash red (fail) at you. Even if it doesn’t flash red, you still don’t know whether your product really passes or not, because the Hi-pot testers you get never have the leakage current threshold written on them, and they are usually so old that they have no datasheet. So fingers crossed and goodness help you.
Then you get another offline SMPS to test, and it again is [2500VAC for one minute and 3mA]…..but at this company they only have a DC Hi-pot tester, instead of an AC one. So of course, you simply calculate what [DC/time/mA] corresponds to what [AC/time/mA]….
…except you don’t, because there’s no way of calculating that.
So you use your sense of logic…..and realise that you must apply a DC voltage of 2500 x SQRT(2).
But for what time?....well, less time than the AC tester that’s for sure, since the AC tester isn’t always at its peak level. Surely an equivalent length of time would be [0.63 * one minute], ie 38 seconds(?) This is because the average of a sine is [0.63 x peak]. Again, you would have to assume that the current threshold would be 3mA…….and lucky you if your DC hi-pot tester allows you to set the current threshold, most don’t, and you’ve no idea what it is.
Whilst you are fumbling about, wondering about this, the other (time served) Engineers in the company declare to the boss, that you are obviously a 2-bit idiot, and that you should spend the rest of your working life doing nothing more than replacing dirty solder-tip-wiper-sponges on the lab benches, and scrubbing the conveniences whilst you're re-filling their solder water bottles.
I mean, it isn’t as if the regulatory hi-pot [Voltage/time/current] settings make any particular sense for offline SMPS. For example, take an SMPS with a Boost PFC front end, with its output capacitor bank…….there is virtually no chance that a typical 50us transient (Line_Neutral) is going to lift the voltage of that capacitor bank up more than a few 10’s of volts anyway……and certainly not up to 1kV. So why the voltage level has to be up to 2500VAC is anyone’s guess. Its appreciable that there should be a length_of_test_time, because high voltage events are cumulative in the damage that they do, so its good to apply the test voltage for sufficient time.
Though, suppose a 2.5kV voltage spike came to the offline SMPS between line and earth. Then , if the offline SMPS output was earthed, then there could be a flashover due to the isolation barrier seeing the full 2500V. [remembering mains cable stray L meaning that for the short transient duration v(neatral)-not-equal-to-v(earth)]…..but no…..there couldn’t be…..the secondary earth would be at neutral potential (and obviously earth potential) and so once again, this transient would simply get quenched to <<1kV by the PFC output caps.
So why we always test to 2500VAC is anyone’s guess.
How long do you think the Hi-pot mystery will continue for?
