I bought broken Fluke 233 for $10. The head unit turned on, but it read rF Err and would flash and then turn off.
So I opened it up and found corrosion all over the PCB which I cleaned off with q-tips and isopropyl alcohol. However it still didn't work. So I gave it a really close inspection and found a tiny short made of blue corrosion which I confirmed with a continuity test.
Alcohol and q-tips made no impact on this last bit of corrosion, so I finished the cleaning with a plastic dental scraper and a magnifying glass. Reassembled, the Fluke now appears to work perfectly. [UPDATE: this did not fully resolve the issue, see below]
I uploaded a full album of photos and descriptions at
https://imgur.com/a/xoucQ2G.
Now I want to test the unit to see if it is still accurate with all the various readings. I have power supplies, resistors, batteries, oscilloscopes, other multimeters, etc, but nothing I would consider lab grade calibrated. Are there any standard methods for this type of accuracy and functionality testing?
