Author Topic: (8FSA) Help me identify this SMD transistor  (Read 1672 times)
Offline raulolivTopic starter
« on: November 15, 2018, 09:33:46 am »
Hello all,
i have in hands a inverter welding machine to be repaired (DECA SIL-147 SIL-417) . I'm not very experienced on this but at first sight it would be just a problem of IGBTs replacement.
Looking closer i found one smd transistor (Q3) in s/c.
I don't have schematics and the case mark is not giving me any clues.
Its a SOT23 case with the inscription 8FSA
Edit:::::
Just found a similar welder schematic, but no references for the parts. The transistor should be a FET:
Can anyone help please?
Thanks
« Last Edit: November 20, 2018, 03:50:38 pm by rauloliv »
Offline t1d
Re: (8FSA) Help me identify this SMD transistor
« Reply #1 on: November 15, 2018, 03:29:07 pm »
Well, I searched, hard, with all the tricks I know, but came up with nothing. I am sure you have checked the part number, but maybe give it another look.
Clean it well. Then, take a little bit of white heat sink grease, or medical zinc cream, and wipe it over the numbers. Sometimes, that helps them to stand out. Use good light, a magnifying glass and younger eyes, if available;-)
I will follow, this thread, to continue to try to help. One option is to identify what the part does and try to find a part that will meet the requirements.
Offline t1d
« Reply #2 on: November 15, 2018, 03:37:12 pm »
Deca contact info:
© DECA s.p.a. Str. dei Censiti, 10 Falciano - Rovereta 47891 Repubblica di San Marino - Tel. 0549 910.711 - Fax 0549 908.360 - deca@decaweld.com
Is it SIL-147, or is it SIL-417?
« Reply #3 on: November 20, 2018, 03:49:46 pm »
Its a SIL-417, thanks for noticing the error. DECA doesn't share schematics or any tech information, i contacted them.
I found a similar welder schematic and i am confident that the the component is a BSS123 mosFET.
Didn't replace it yet because unfortunately i found other complicated issues issues with this ......  :(
Regards,
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #4 on: November 20, 2018, 04:24:36 pm »
That's probably because they don't have that info to start with. It looks like a generic rebadged Chinese machine to me.
We never got board level schematics for our house brands when I was in the game, not even for the Flagship rebadged EWM models, let alone the Chinese ones. If even Cigweld and BOC can't get PCB schematics for their exclusive models, I wish you good luck. :)
It was usually a game of swapping boards, and only going to board level repair if things were obvious. (Like the period of time that EWM thought pop-riveting the heat sinks to vregs with the thin tabs was a good idea, then wondered why they all overheated and let the smoke out.....)
« Last Edit: November 20, 2018, 04:26:25 pm by TERRA Operative »
